Mahogany boat console for Boston Whaler
« back to Joinery forum
Forum topic by Surfhunter22 posted 01-28-2018 03:26 AM 281 views 0 times favorited 5 replies Add to Favorites Watch
View Surfhunter22's profile
Surfhunter22
2 posts in 28 days
01-28-2018 03:26 AM
Topic tags/keywords: boat mahogany joinery
Any tips on joinery for a classic 15 Boston whaler interior that I’m building out in mahogany? The original just had butt joins and screws, I’m planning something with rounded corners and no visable screws. Yacht manufactured build help pods with edge glue and a layer of fiberglass on inside. I’m wondering if a sliding dovetail cross brace and some screws/corner blocks on the backside may be prudent. Sides are true 1” mahogany top will be 3/4 mahogany.
Here is a mock-up.
5 replies so far
View Andre's profile
Andre
1669 posts in 1715 days
#1 posted 01-28-2018 04:34 AM
you could go with splines and epoxy it all together?
runswithscissors
2657 posts in 1934 days
#2 posted 01-28-2018 04:52 AM
You could get rounded corners by using something like brick mould. I’m sure you would have to make your own if you want to go with mahogany.
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#3 posted 01-28-2018 04:56 AM
I grew up in the Florida Keys and on Whalers. First one was a 15 like yours, then traded up to a 17. I eventually wound up going to a fiberglass console. Those tri-hulls pound the crap out of the boat, and the wooden consoles just couldn’t handle the constant abuse. Whatever you wind up doing, over-build it or it will come apart in pretty short order.
View John Smith's profile
John Smith
456 posts in 72 days
#4 posted 01-28-2018 02:47 PM
X2 with Brad:
you need to put a LOT of thought into how wood ties in with fiberglass on tri-hulls
compared to a deep-V. the tri-hulls were my worst experiences in rough water. (and still is).
pay special attention to the joints and anchor points. mahogany will look awesome when you are done !!
a couple of good boat sites are fiberglassics.com and thehulltruth.com
Surfhunter22
2 posts in 28 days
#5 posted 01-28-2018 05:39 PM
Agree it needs to be built for abuse. Having percussion joinery is a risk since I’m sure any movement will result in cracks in the finish.
I plan to use a 3/4 round over but to round the board edges. It would be nice to have some pieces that could be disassembled in the future but I don’t see that as an option. It will receive ~ 3 coats of west systems and 3-4 coats of varnish once done.
