Currently my shop is located in a 16×24 garage that we also do car repair in so i have to be able to clear enough space for a car/truck to pull in. So my idea was to make a mobile assembly table that i can move outside the door once every month or two but I didn't want it to move while working on it. I also didn't want to have wheels on it all the time because I think it would get in the way. The table in the drawing below is currently the table is 48×72 in the drawing but I am going to redraw it for 48×48 because it takes up more space than I thought it would.
I was just wondering what you guys though about the design of the wheels. I'll use pneumatic casters rather than the rubber ones in the drawing because it needs to go over gravel. The casters and frames will most likely have to be welded rather than wood to provide more strength. The way the wheels work is by just inserting them into the holes in two 2×4 and 5/8 thick gable end and pushing down on the metal bar with your foot and push it into the latch. I think the design could work but I am not sure if it would be able to hold the weight when the table is loaded with tools, so I was just wondering what you though and if you have any suggestions or alternatives.
I like it, and I always like the space-savers, like the flip down planer. One concern though, be very careful about aligning that section of the top so it is flat, and locks well, you dont want to forget about a rise or depression there and screw up assemblies. also, you will have to round the edge of the cutout section or the corners will catch, or you will have to have a relatively large slot for clearance. rotating a rectangle like that is like putting a square peg in a round hole, the hole has to be much larger than the square to accommodate the corners. Just want to make sure you take this into consideration since your drawing seems to still have this issue.
Good luck with your build
@drewahant - the torsion box around the flip top in set back a inch to allow room for it to turn around but i think i might need to add a more room to be sure it don't get stuck. I guess placing the flip top in the right spot will be very important because i wouldn't want a rise or depression there like you said.
any thoughts about if the lifting mechanism will even work or not? I think it might but i am not sure because it will have a fair bit of weight in a 48×48 table with tools in it. any help will be appreciated.
Rather than removing the wheels all together, have you considered installing furniture pads to lift the wheels off the ground so it doesn't slide around? Just a thought.
I'd have serious concern about the caster design. The way you have it, as far as I can tell, all of the weight will be resting on the pivot pins, not on the caster brackets or the casters. That's a lot of stress on the pins and the wood they're in, especially over time.
There are several ways to get around this while keeping a similar design. I think I'd look at a simple hinge so you lift the end and swing the wheels under for simplicity. It would require you to lift the end of the table a bit higher but you have to lift it either way.
The simplest solution, and the one I've used on several mobile stands, is quality dual locking casters. It's not quite as rigid as having it sitting on the floor, but it's darned close if you use good casters mounted properly and positioned well.
All that being said, your design may work just fine for years. I'm an engineer so I tend to over analyze ;P You can always give it a shot. If it doesn't work out, there's no damage to the table if you remove it.
That is a sweet design! Like Kenny said you might want to reconsider those wheel. I've see on the workbench smack down forum where Rocker has got flip up wheels. Flip them down and they are under the bench. You might want to take a look at those. The weight of the bench would be on top of the wheels when you move it.
I can for see your brackets getting sprung from the weight of the bench as you move it.
I have done a similar design using levers to raise the casters and I haven't been happy with it. I would suggest just getting fully locking (swivel and rolling) casters if you can. The ones I have on another table don't move at all even with relatively heavy pushing.
Yeah… but only when in the down position, which is only when you are moving the table. In the up position, the foot lever is raised and not sticking out any further than the caster themselves. I made my own for a mobile base as I needed more capacity than the Rockler ones, but the concept is the same… here is what they look like (before being painted!) in the raised and lowered positions:
And the foot lever can be flipped back further to an almost upright position if needed, placing it basically up against the mount point and completely out of the way.
I like the idea, BUT I don't think I would like it in my shop. When using the planer, I like to be able to walk right around the machine, after feeding the board(s) to support it on the outfeed side. With this design, it would be several steps to get around the machine. It may not seem like much on paper, but in real life, I think it would get old, quick. Just my thoughts though, YMMV.
I would just us total-lock casters. Both the swivel and wheel rotation is locked when you step on the small lever.
I agree with ste6168 regarding the ability to walk around the planer being important. At minimum, I would change the orientation of the planer so the boards pass over the cart lengthwise. This will at least allow access to the depth crank on your planer. Also the more infeed / outfeed support you have, the better.
I usually don't love the idea of flip-top carts. Dedicated tool stations have the advantage there, but I understand you are trying to save some space. Nice rendering.
The only problem I see with using double-locking casters is it doesn't give you any ability to adjust the height… which may or may not really be a problem. With something that lifts to move, either using lifting caster brackets like the ones I showed or using the original pivoting design, you can place adjustable feet on the bottom of the table. That not only allows for fine tuning the height to exactly match the table saw height, but it also lets you compensate for uneven floors or making the work surface level if needed. Fixed swivel casters along with adjustable lifting pads would also work for that, similar to how many mobile bases (like the current one at HF) are setup. And actually, that configuration would allow the casters to be placed under the table completely out of the way, with just the lifting pads outboard, so no 'ankle busters'
I tried this once. Great idea I thought at the time. Got it built and had every intention of pulling it out and using it as a assembly table then put it back. It is 24" deep and 8 feet long and 30 inches tall with casters. It has everything in it you might need. Drills, planer, saws, sandpaper, supplies etc etc. WEIGHS A TON. Even empty with all the drawers in it I knew this was not going to work as planned. In 15 years it has not moved. I imagine the casters are flat by now. My neighbor had same problem so he built just a table, heavy duty out of PT 2×4's, painted it and keeps it outside under a custom tarp I sewed up for him. As a bonus it doubles as a extra picnic table when they have company.
Brad I don't think those will work he needs bigger wheels to go across gravel.
I would suggest instead of making the casters retractable, design some type of retractable stabilizer leg that takes the weight off the casters when engaged. It only has to contact the ground enough to keep the bench from moving. That way, the casters are under the bench not sticking out with all torque on the rods.
Since hes a car guy, maybe some variation of an upside down car stand?
Don't need a fancy mechanism you can lift if with a crow bar and a block of wood…...
I've seen a YouTube where someone mounted casters on a removable frame that he could lift up a little on end of bench and put in place. Seemed to work well for him. Wish I could find link…
Ouch… ok, I admit, I didn't really read the original post entirely, just looked at the pretty pictures and scanned through the responses. And I certainly didn't catch the part about using pneumatic casters. I retract my suggestions, and will now slink away in shame
Those would be great for a small bench, but watch the video on that page. Those castors are only rated for 100lbs/each and are only held in by one screw.
Might want to consider using something like these instead:
Great idea just a thought though if you put a bar on each caster you would be able to leaver all to lift all you have to do is off set the bars by the diameter if that makes sense other than that how do you lift the one without a leaver? Regards John
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
