Looking for
Forum topic by JTTHECLOCKMAN posted 01-27-2018 08:44 PM 139 views 0 times favorited 1 reply Add to Favorites Watch
View JTTHECLOCKMAN's profile
JTTHECLOCKMAN
192 posts in 3054 days
01-27-2018 08:44 PM
I have a small project I am working on. The top has a couple of rounded outside edges and a rounded inside edge. I want to duplicate the same shapes but 1” from the outside edge. I want to cut the center out but the remaining piece needs to be equal all around. I want to place plexiglass in the center. I can figure the obvious section of straight cuts but the curves are not coming out even and it will show. I can easily cut the inside out with a scrollsaw. That is not the problem. What I am looking for either a factory made contour guide or a handmade one. I hope I am explaining what I want to do plain enough.
I thought I saw one time a jig that can do this and it had 2 points so that as you trace around the curves those 2 points need to touch the wood at all times but a center point that holds the pencil will travel in the same plane at all times. Not sure what that tool is called but again looking for help and maybe a link to a tool or a photo of one made. The project is 6” X8” so it is not a large top for a box. Thanks in advance.
-- John T.
1 reply so far
View wuddoc's profile
wuddoc
267 posts in 3623 days
#1 posted 01-27-2018 11:16 PM
You may find the information you need on you tube under drawing an elliptical curve or arch.
Good luck.
-- Wuddoc
