Which Dado Set to buy
Forum topic by AlmostRetired posted 01-27-2018 08:11 PM 1419 views 0 times favorited 11 replies Add to Favorites Watch
View AlmostRetired's profile
AlmostRetired
219 posts in 953 days
01-27-2018 08:11 PM
Hello everyone, I hope you guys are all having a good weekend. I am researching a dado set and because I am using a SawStop they recommend the following sets.
· Forrest Dado King DK0824XXX (5/8” arbor)
· DeWalt DW7670
· Tenryu GMD-20340
· King Canada KSC-8000
· Amana 658040
Which one would you buy and why? Any good or bad experiences to date?
Also, none of these offer any greater width than 7/8”...I don’t think. Is there any reason I would need a set that is bigger than that? If I ever do I can use a smaller one and run it through twice I think.
Thanks,
Roger
11 replies so far
View knotscott's profile
knotscott
8179 posts in 3615 days
#1 posted 01-27-2018 08:46 PM
The DW7670 gets best bang for the buck award IMO. It outperforms the typical $100 group, and gives a taste of the best sets for a lot less. Can often be found in the $120 range on sale.
I doubt your arbor will handle anything wider than 7/8”, and even to fit the whole stack on sometimes you need to leave off the washer.
View TungOil's profile
TungOil
1086 posts in 734 days
#2 posted 01-29-2018 01:03 AM
In 45+ years of Woodworking I have never cut a dado wide enough to need all of the chippers. If the Forrest is in your budget I would highly recommend it.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View jonah's profile
jonah
1972 posts in 3538 days
#3 posted 01-29-2018 01:54 AM
If I ever need a wider dado than ~3/4”, I just move the fence and make two passes. Certainly that’s easier than trying to stuff all the chippers onto the arbor.
View JackDuren's profile
JackDuren
388 posts in 1199 days
#4 posted 01-29-2018 02:07 AM
Freud or Amana 8”. Freud is a good deal most of the time…
View Carloz's profile
Carloz
1147 posts in 831 days
#5 posted 01-29-2018 01:07 PM
- TungOil
I use the full width quite regularly, for example when making tenons or lap joints.
View msinc's profile
msinc
569 posts in 743 days
#6 posted 01-29-2018 01:18 PM
Everyone says a different brand…can I ask this, forget about a sawstop, just dado blades in general; is there a brand that stays sharper longer in average wood? or because most folks don’t use a dado blade all day long does it matter? Is there one that cuts a nicer, smoother dado? Thanks for any info…
View Firewood's profile
Firewood
576 posts in 1873 days
#7 posted 01-29-2018 02:21 PM
Before I got a Sawstop, I used the Freud 206 set. It was ok, but the bottoms weren’t as clean as I would have liked. I now have the DeWalt set and it seems to cut much cleaner. In fact, I had the unfortunate opportunity to run a second set on my saw and it was just as good as the first.
-- Mike - Waukesha, WI
JackDuren
#8 posted 01-29-2018 02:24 PM
Everyone says a different brand…can I ask this, forget about a sawstop, just dado blades in general; is there a brand that stays sharper longer in average wood? or because most folks don t use a dado blade all day long does it matter? Is there one that cuts a nicer, smoother dado? Thanks for any info…
- msinc
It’s not the different brands, it’s the price…I’ve used a lot of dado blades in cabinet shops and Freud or Amana seem to be the Norm..
Personally I use a router in the table saw wing more than dado nlades now. Rarely use dado blades…
Carloz
#9 posted 01-29-2018 03:46 PM
- JackDuren
Do you have experience with other dado blades ?
Personally I use a router in the table saw wing more than dado nlades now. Rarely use dado blades...
- JackDuren
That explains. People who do use dado blades notice that Freud is quite a mediocre dado stack. A regular flat tooth blade will give you a much better cut than Freud dado. The latter produces deep notches at the bottom of the slot that are only acceptable when the slot is covered by wood.
knotscott
#10 posted 01-29-2018 05:34 PM
- msinc
I’ve used the Freud SD208, DW7670, Systimatic 42T Superfine, Freud SD508, and the Infinity Dadonator. Not all are suitable for use with a Sawstop due to the anti-kickback shoulders. All were pretty respectable sets. The cleanest cutting IME was the Infinity Dadonator. The DW7670 is the best bang for the buck IMO at ~ $120. It gets really expensive to compare the really good sets side by side, so it rarely happens outside of a magazine review. The Dadonator, SD508, Forrest Dado King, and Ridge Carbide Dado Master are the usual finalists amongst the premium sets.
How long a blade stays sharp is dependent on several variables including cleanliness, moisture content, heat build up, technique, material hardness, and many others, so it’s almost never an apples to apples comparison, and is tough to accurately predict or compare. A good set made from quality materials that’s well maintained should last a hobbyist a very long time.
View hairy's profile
hairy
2783 posts in 3771 days
#11 posted 01-29-2018 05:41 PM
I cut these with a Freud SD208 for this project.
These are 7/8” wide x 1/4” deep. Clean enough for what I do. I bought the set in 2010.
-- My reality check bounced...
