Squaring blade to miter slot... problems...
Forum topic by LucasWoods posted 01-27-2018 03:59 AM 773 views 0 times favorited 16 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1572 days
01-27-2018 03:59 AM
I am sitting at .56+mm difference from the front of my blade to the back of the blade. I have already moved the back trunnion as far over as it can go.
What are my options?
I own a Grizzly G1022 contractor saw.
-- Colorado Springs, CO - USAF
16 replies so far
View Rayne's profile
Rayne
1124 posts in 1779 days
#1 posted 01-27-2018 04:11 AM
Did you move the front in the opposite direction?
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#2 posted 01-27-2018 04:11 AM
- LucasWoods
Try moving the front the opposite direction.
View jerryminer's profile
jerryminer
944 posts in 1681 days
#3 posted 01-27-2018 05:20 AM
If the above advice doesn’t work, you can probably slot-out the bolt holes.
View IantheTinker's profile
IantheTinker
273 posts in 366 days
#4 posted 01-27-2018 05:28 AM
I suppose you could always shim the blade somehow, or perhaps your arbor is off a smidge. The other guys had better advice, I just wanted to throw out someth8ng different. Wouldn’t want to be a conformist, right? :)
-- opiningminnesotan.com
LucasWoods
#5 posted 01-27-2018 06:36 AM
I was hoping for suggestions where I didn’t have to move the other trunnion. It just means about 45 minutes of taking the cabinet off so I can reach the front trunnion to loosen the bolts. But it looks like that is the next logical step.
What tolerance should I be shooting for?
And how do I slot out the bolt holes if it comes to it?
jerryminer
#6 posted 01-27-2018 07:24 AM
This is a personal choice (some folks are more tolerant than others) but I would aim for .005” or less.
Round file or die grinder.
View toolie's profile
toolie
2148 posts in 2868 days
#7 posted 01-27-2018 01:53 PM
.001” is achievable with a bit of patience. It’s usually a good idea, assuming table mounted grunions, to loosen all bolts leaving just one “snug” to act as s pivot point during the alignment exercise.
LucasWoods
#8 posted 01-27-2018 04:24 PM
Thank you. I got a few round files and filing the hole where the trunnion bolt goes intonwont affect the bolt being able to be tightened?
LucasWoods
#9 posted 01-28-2018 02:23 AM
Filing the hole won’t mess with the threads for the trunnion bolt? It will still tighten down?
jerryminer
#10 posted 01-28-2018 02:44 AM
Don’t file the threads—file the through-hole.
View sras's profile
sras
4969 posts in 3368 days
#11 posted 01-28-2018 03:23 AM
I have never had to deal with this, but I thought this discussion would have focused on shifting the table instead of the trunnion. Am I missing something?
jerryminer
#12 posted 01-28-2018 03:35 AM
- sras
In a “contractor’s saw” the trunnions are attached to the table, so the adjustment is made in the trunnion-to-table connection. In a “cabinet saw” the trunnions are attached to the cabinet, so the adjustment is made in the table-to-cabinet connection.
LucasWoods
#13 posted 01-28-2018 03:54 AM
Duh thank you all lol I completely spaced the trunnion itself has no threads.
View sras's profile
sras
#14 posted 01-28-2018 04:32 PM
In a “contractor s saw” the trunnions are attached to the table, so the adjustment is made in the trunnion-to-table connection. In a “cabinet saw” the trunnions are attached to the cabinet, so the adjustment is made in the table-to-cabinet connection.
- jerryminer
Thanks! I learned something…
View AxkMan's profile
AxkMan
65 posts in 365 days
#15 posted 01-29-2018 03:21 AM
That’s good advice.
