Lateral Adjusting Lever Question
Forum topic by pete79 posted 03-30-2011 06:22 PM 4950 views 1 time favorited 18 replies Add to Favorites Watch
View pete79's profile
pete79
154 posts in 3259 days
03-30-2011 06:22 PM
I have an old Stanley Bailey #5 bench plane that I recently acquired and restored. The plane works great except that when I got a new Hock blade and chip breaker, the lateral adjusting lever no longer engages with the blade. Since i’m very new to hand planes, I’m curious about two things:
1. Are you supposed to be able to adjust the blade slightly using the lateral adjusting lever with the cap iron locked down?
2. If so, has anyone had this problem after puting on an after market blade? My guess is this might be happening because the Hock blade is thicker causing no contact between the lever and the chip breaker.
Any ideas?
-- Life is a one lap race.
18 replies so far
View Bertha's profile
Bertha
13550 posts in 2811 days
#1 posted 03-30-2011 06:26 PM
Is the ring on the base of the lateral aduster (at the frog face) engaging into the slit in the new blade? I routinely use the lateral adjuster with the lever cap clamped. I haven’t ruined one yet. How much pressure are you applyng when you close the lever cap? thinking outloud now.
Bertha
#2 posted 03-30-2011 06:27 PM
Oh, and I’ve got hocks in most my Stanleys, including my #5.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3032 days
#3 posted 03-30-2011 06:39 PM
FWIW, my old Sargent 418 (#6) has a Hock in it and still engages.
My only suggestion might be to adjust the distance (probably increase) the chip breaker is from the end of the blade. What this does, is to allow the height adjusting “finger” to be adjusted to be more nearly vertical/perpendicular when the blade is at the preferred cutting depth. You may have to also adjust the frog fore OR aft in combination with the chip breaker distance until you find a sweet spot.
pete79
#4 posted 03-30-2011 06:48 PM
Perhaps I used the incorrect terminology here – but the piece that I called the lateral adjuster is the long thin lever that has a small circle piece on the end of it. The lever extends out and over the top of the rear tote.
The small circle on the end of this lever fits between the slot in the blade, but does not engage the chipbreaker at all. I’m looking at it and it appears to have a bend in it, which may be the culprit? Should this lever be straight?
pete79
#5 posted 03-30-2011 06:54 PM
Just straightened the lever out a bit and it worked….guess that was a dumb question. Thanks for the input though.
HorizontalMike
#6 posted 03-30-2011 06:55 PM
Geez, I guess I should pay attention here! In that case I would just carefully bend the disk end “up” slightly (like 1/16” or less) while holding firmly down on the pin aka pivot point of the lateral lever. Obviously do this at your own risk, but that is what I would do if it was called for. If you think about it, the difference in thickness of the Hock blade and the original is pretty small, so a SMALL adjustment should do it.
Just saw your FIX after posting this. COOL! Glad you figured it out. Have fun using it!
Bertha
#7 posted 03-30-2011 07:01 PM
I’m not imagining how this round knob could engage the chipbreaker (?). Sounds like you fixed it anyway. Good job.
pete79
#8 posted 03-30-2011 07:07 PM
It could be my own lack of understanding on how hand planes work, since this is my very first one. I assumed that the flat round disc engaged the chipbreaker and moved the breaker/blade assembly from that pressure. Or, does the adjusting lever adjust the breaker/lever assembly by pressing on the sides of the slot in the blade? Does that make sense? I’m probably talking out both ends now.
HorizontalMike
#9 posted 03-30-2011 07:15 PM
The small disk end of the lever engages the slot of the blade. May have been bent down from use, mishandling in the past, who knows but by bending it up slightly, you are back in business.
Smitty_Cabinetshop
15519 posts in 2737 days
#10 posted 03-30-2011 08:01 PM
Pete – One thing to repeat with care, each time you remove the lever cap and iron assy, is the re-seating of the iron against the frog. Many times it takes a couple of seconds of fettling to get the iron to properly engage the lateral adjustment’disk’ and create a nice, flat sandwich of metal. Do this check before engaging the lever cap or you’ll likely bend the disk out of place again. Good luck, and welcome to hand planing!
View swirt's profile
swirt
3037 posts in 3090 days
#11 posted 03-30-2011 08:21 PM
Right. The depth adjuster lug does engage the chipbreaker but the lateral adjuster (a wheel on some or a tab on others) only engages the blade, not the chipbreaker.
View David Kirtley's profile
David Kirtley
1286 posts in 3116 days
#12 posted 03-30-2011 10:47 PM
Also remember that the replacement blade is thicker than the stock blade. The lever cap screw will need to be backed off.
View JFobare's profile
JFobare
41 posts in 3190 days
#13 posted 04-27-2011 04:17 AM
Hey All, I’m hoping to jump in here with another question, if I may…..I just put a new Hock blade and breaker on my #4 Stanley and everything is contactinig the way it should, however, for the life of me I cannot get the blade to remain straight. I have adjusted the tension on the lever cap and messed with the lateral adjustment but its still producing a small gouge on my board on one side or the other. What am I missing?
View Dan's profile
Dan
3630 posts in 2999 days
#14 posted 04-27-2011 06:49 PM
JFobare- is your lateral adjustment moving as you are using it? It could be that its just really loose. I have a few planes that have rather loose adjustment levers and I have to check them rather often to make sure the blade is still straight with the mouth. I have no idea how to tighten a loose lever.
Also, have you put a camber or rounded off the corners on your blade at all? If you add a slight camber to the blade or even knock down the corners when honing it then that should help from getting gouges on the sides. That will prevent the corners from digging into the wood if the blade is not perfectly straight.
-- Dan - "Collector of Hand Planes"
JFobare
#15 posted 04-27-2011 07:33 PM
Hey Dan…the lever is loose in the slot in the blade and I had to bend it up for it to properly engage (it was just sliding back and forth under the blade). Is there a rule of thumb to how tight the lever cap should be? Should I straighten the blade in the mouth and pinch it there with pressure?
No I haven’t rounded the corners, I had just gotten the blade in the mail and was anxious to put it on:-) But I will definitely give a shot…many thanks!
