South Bend Lathe Company
Forum topic by dbw posted 01-26-2018 11:05 PM 500 views 0 times favorited 6 replies Add to Favorites Watch
View dbw's profile
dbw
207 posts in 1757 days
01-26-2018 11:05 PM
Topic tags/keywords: drill press chuck
Has anyone ever heard of this company? I am thinking of buying one of their drill press chucks.
-- measure 3 times, cut once
View MrUnix's profile
MrUnix
6891 posts in 2319 days
#1 posted 01-26-2018 11:15 PM
Outstanding machine lathes – I got one of the old model 415’s. Didn’t know they made chucks though.
See here for some history.
View Clarkie's profile
Clarkie
455 posts in 1961 days
#2 posted 01-27-2018 12:27 AM
I agree with Brad, I used to own a 9” toolroom lathe. Fine piece of equipment.
runswithscissors
2823 posts in 2145 days
#3 posted 01-27-2018 04:41 AM
A section of Grizzly’s catalog is devoted to South Bend. Never checked for chucks, though.
View dbw's profile
dbw
#4 posted 01-27-2018 06:26 AM
They also make accessories for lathes, mills, and drill presses. They even have workbench legs. Who knew!
https://southbendlathes.com
View MrRon's profile (online now)
MrRon
4992 posts in 3364 days
#5 posted 01-28-2018 07:52 PM
South Bend lathes were the industry standard back before 1959 when they were made in the USA. I don’t know how good they are now. I believe they are made in Taiwan. There are 3 levels of quality available today in machine tools (and other products as well). The real expensive and mostly industrial grade machines come from Japan. The best consumer grade machines come from Taiwan and the rest come from China. There are a few coming in from South Korea, but nothing big at the moment other than farm and construction equipment. I have heard of some good machines coming from India, but not available here. Off course we can’t forget machines from Europe, but very expensive.
To answer your question, a drill chuck will fall into one of the 3 quality grades listed above and prices will vary accordingly.
View CaptainKlutz's profile
CaptainKlutz
459 posts in 1615 days
#6 posted 01-28-2018 09:05 PM
If tool was made prior to 1960, was made is USA and considered to be one of best lathes available. These tools last many lifetimes.
If made 1960-1975 (when America tool makers were struggling due imported knock offs); then tools are are still considered excellent, but there will be some Asian imported castings/parts, especially on lower end models.
South Bend tools made ~1980 forward have murky mfg history due various ownership changes, but most tools came from parts made in Taiwan.
Today SBL is based in same location as Woodstock Int, and tools are imported/distributed by Woodstock Int. (which is affiliated with Grizzly as well). If you read the marketing from SBL carefully, you will see they make no mention of where machines are made anymore.
The current generation of larger 10”- 18” tool room lathes have fit/finish typical of higher end Taiwan made tools, and are considered a good value if you need a new lathe. The only limitation with the current SBL lathes is there are tools with better precision. So read specs and assess you needs carefully: as when it comes to machine tools; “you get what you pay for”.
