Router Table Material ?
Forum topic by bubinga posted 03-30-2011 01:25 PM 1825 views 0 times favorited 10 replies Add to Favorites Watch
View bubinga's profile
bubinga
861 posts in 2571 days
03-30-2011 01:25 PM
Topic tags/keywords: router shaping milling router table
This is what I am making my NEW router table top from
Old one I bought has been warping more and more over years
This is a manufactured bench top surface I got on eBay for 50 bucks
21”X 48”
PVC laminate , Polyurethane (PU) over MDF
PVC TEXTURED LAMINATE THERMOFUSED 1.5” THICK VACUUMED FORMED ON STRONG MDF
I think this might not warp
What do yall think ?
-- E J ------- Always Keep a Firm Grip on Your Tool
10 replies so far
View ken_c's profile
ken_c
323 posts in 3066 days
#1 posted 03-30-2011 02:28 PM
double 3/4” MDF followed by both side laminated with high pressure laminate. putting the laminate on both side puts the double MDF in compression lessening the likelihood of warpage… This is more than my opinion, this is time tested and proven advice. I have one example of it in my shop and I am sure that there are many more. Not only does it work, it is very inexpensive. You should be able to easily find the laminate as scrap for free and the MDF can be scored at a big box on the cheep too…
bubinga
#2 posted 03-30-2011 02:56 PM
I have built a router table top ,and it had high pressure laminate on all sides
The one I bought had high pressure laminate on top and bot, with edge banding
I have enough of all the right material in the shop to make one
I am saying ,this ,manufactured bench top surface ,is what i am going to use.
And because it is beefy,and PVC LAMINATE THERMOFUSED,VACUUMED FORMED ON STRONG MDF.
AND an inch and a half thick .
I think it will be very very good for a router table top
Do you agree ? or Disagree ?
bubinga
#3 posted 03-30-2011 05:26 PM
HEEE,HEEEE, cr1
View ScottN's profile
ScottN
261 posts in 2583 days
#4 posted 03-31-2011 02:08 AM
concrete…hmmm…you know, why not?
-- New Auburn,WI
View surfin2's profile
surfin2
51276 posts in 3040 days
#5 posted 03-31-2011 03:03 AM
Ken, I think your the first person that said to put laminate on both sides of the table outside of me…
That’s the way I made my top (Norms version) I don’t understand why Norm didn’t do both sides???
He gives you the impression that all those screws he put’s into the 2 MDF sheets will stop from warping…
-- Rick
View mchuray's profile
mchuray
81 posts in 2902 days
#6 posted 03-31-2011 05:17 AM
Hay guys what kind of glue did you use to laminate the two pices of MDF together? Contact cement? Titebond III ? Hide glue?
Thanks,
Mark
bubinga
#7 posted 03-31-2011 05:30 AM
Contact cement
mchuray
#8 posted 03-31-2011 06:37 AM
Thanks,
Mark
surfin2
#9 posted 04-01-2011 02:33 AM
I usedTitebond III
-- Rick
surfin2
#10 posted 04-20-2011 03:01 AM
Contact cement for laminate to MDF
-- Rick
