Electrical advice is playing with fire and life safety issues.
Forum topic by TopamaxSurvivor posted 784 days ago 2026 views 0 times favorited 77 replies Add to Favorites Watch
TopamaxSurvivor
13192 posts in 1845 days
784 days ago
Topic tags/keywords: electrical advice playing fire life safety issues motor over current protection overload
About 40 years ago I asked a plumber on a job how to do something in my house. He asked why I didn’t hire a plumber to do it. I told him I could run pipe. His response was anyone can run pipe, but if you want it done right and not leak, you need a plumber.
The same goes for electrical systems. Anyone can run wire and pass inspections. A few days ago, I had a conversation with a state inspection supervisor about corrections for issues that were missed by the previous inspection when the building was built. His response was he was offended that anyone would expect inspections to be 100%.
A friend on here has pointed out there may be some risk giving free advice on the web. There is so much bad information being given on LJ about electrical systems, I just cannot let it go uncorrected. In spite of being well intended to help some one out, you are still playing with fire and, in some instances, life and death issues.
Reading a few facts in a code book or article is only one of many points to be considered in any installation. Every article in the code is affected by many others. None of them stand alone.
25 years ago, the supervision at L&I wanted me to become a state electrical inspector. They said they were having a very difficult time finding qualified people to do the inspections. The choices were boiling down to lowering their standards either by doing fewer inspections or accepting unqualified inspectors. In the end, I could not deal with all the people working in the trade that should not be licensed and were on the edge of committing arson and manslaughter instead of electrical work. I have heard many comments from customers asking about the degradation of the field personnel in the last 10 – 15 years. The push for cheaper labor is getting to critical mass. Unfortunately, some unsuspecting victims will be paying a very high price; hopefully, it will just be property loss.
One of the LJs in the local area asked me about installing a sub-panel. Because of all the misinformation being espoused here on LJ, he thought it was a requirement. The fact is most FHA and other lender inspectors require consolidation of sub-panels into a main panel. Unless it is going to a separate building, if there is space in your main panel that is the place for the circuits.
One demonstration I used to use was putting a paper clip across an outlet causing a short circuit. Most the 15 and 20 amp circuit breakers on the market would melt it before the breaker tripped. Fuses and Sq D or Cutler Hammer breakers would trip before the paper clip even got hot. Fuses of the proper size are safer than circuit breakers, but people do not want the inconvenience. With breakers of that quality in most installations, do you really want to over size the over current protection? That over current protection is supposed to stop all catastrophic failures and fires whether they are part of the building or in utilization equipment.
Overload protection on most motors is over sized, especially what is provided external to the motor. It is normally too slow to protect a motor with locked rotor current when it becomes physically jammed. It is not short circuit protection. The breaker in the panel is supposed to serve that purpose whether the problem is in the building wiring, in the attachment wiring or the motor.
Be very careful what and who you believe. If you get some bad advice about WW, you might ruin an expensive piece of wood; have finishes you don’t really like or even a gooey mess that will not dry. You probably aren’t going to have a fire or worse. Electricians are just like fighter pilots and every other trade and profession. Very few aces!
77 replies so far
12053 posts in 1510 days
#1 posted 784 days ago
good information bob
and here i was going to make diamond rings
i saw a video about how to cut diamonds
looks easy
a little flat chisel
a little hammer
i could get rich
just send me your rough stones
TopamaxSurvivor
#2 posted 784 days ago
If I had any, I would probalby try to break them up myself ;-))
View bubinga's profile
bubinga
867 posts in 837 days
#3 posted 784 days ago
You got a point there ,Top
-- E J ------- Always Keep a Firm Grip on Your Tool
View knotscott's profile
knotscott
4192 posts in 1545 days
#4 posted 784 days ago
You do make a good point Bob. Your post is an excellent eye opener.
TopamaxSurvivor
#5 posted 784 days ago
I was a bit hesitant to post it. Not sure how it would be received, but people do not realize how high the stakes can be. I have seen too many catastrophes in the last 40+ years. Most of them preventable by proper installation and or maintenance methods.
View littlecope's profile
littlecope
2329 posts in 1671 days
#6 posted 784 days ago
Great Advice Bob…
My Brother is an Electrician too, and he says the same things…
View saddletramp's profile
saddletramp
998 posts in 807 days
#7 posted 784 days ago
Bob, although I understand a little bit (key word is little) about the principles and mechanics and even the physics of electricity, I am certainly not an electriciian and I would never presume to offer advice to anyone on wiring or ciircit breakers or the like and conversely I would never ask advice from anyone other than a qualified electrician (fortuneately my SOL is one).
Even though I am sure that in principle you are absolutely correct, it still leaves me with a quesion and believe me I am not trying to be sarcastic. Without a separate dedicated circuit for each electrical device, how can you size each circuit to be an exact fit for everything that you plug into it? Again, I am not trying to be sarcastic, I just don’t understand (not an uncommon occurrence for me LOL).
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View ken_c's profile (online now)
ken_c
188 posts in 1331 days
#8 posted 784 days ago
I would expect this stems from yesterdays questions around a 220v saw and a 60 amp breaker. Or at least that was your tipping point. And i agree with you, if you don’t know what you are doing call a professional that has the proper credentials. It’s not worth the risk. That said, get references and check those credentials because there a a lot of unqualified ”qualified” people out there doing things that they shouldn’t be doing…
View Steve Donnelly's profile
Steve Donnelly
114 posts in 1038 days
#9 posted 784 days ago
At last some sense and wisdom when it comes to electrical!
Too many folks have no idea of the risks they take when working on or adding to electrical systems..
-- Steve, The Hill Country, TX; www.themillworkguys.com
View Bertha's profile
Bertha
13111 posts in 862 days
#10 posted 784 days ago
I’m glad you weren’t too hesitant to post it. I’ve been hoping for a post like this from someone with some experience. When I moved into my new town, I asked around about the best electrician & fired two just because I didn’t like their attitude. It’s simply too important to be left up to anyone you don’t completely trust. It’s going to be expensive. Why wouldn’t it be and what isn’t?
View ScottN's profile
ScottN
259 posts in 849 days
#11 posted 784 days ago
Forums are a breeding ground for misguided information. If you ask a electrical question here you’ll get a lot of different answers some good and some bad, the person asking the question wouldn’t know which is which unless they had a better understanding of how electrical works. And if you ask that same question on an electrical forum you’ll get more of the same answers and more creditable.
I think one of the best things someone can do is buy one of the basic wiring and advanced wiring books you’ll find in any big box store like home depot ,lowes,menards ect…
-- New Auburn,WI
14858 posts in 2387 days
#12 posted 784 days ago
Well said, Bob.
I’m a fairly mechanically-inclined individual, but I don’t know much about electrical work. When I see a question posted on how to do something, and the poster gets four or five totally different responses, I have no idea which of them, if any, is correct. For that reason, I plan on leaving the vast majority of my electrical work to a qualified professional.
View spunwood's profile
spunwood
1160 posts in 1005 days
#13 posted 784 days ago
Thanks man, Good advise.
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
View GaryL's profile
GaryL
988 posts in 999 days
#14 posted 784 days ago
Excellent post Bob!
I know from your many posts that you are a knowledgable electrician that actually cares about doing the job at hand correctly and safely. I believe you have also said in the past that it is difficult to diagnose a problem or offer advice to a possible upgrade without actually being there to see all the factors involved. Some important details can be left out in a simple post. Having a local, qualified professional that can look at the particular project needs first hand is always the best way to go.
Thanks for bringing this up.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View crank49's profile
crank49
2286 posts in 1140 days
#15 posted 783 days ago
Since I was in that discussion about the 60amp outlet and the table saw I feel I should comment here. I have offered advice when I felt I could assist someone, and, on occasion, to try to dispell some bad information I have seen posted by others. I usually try to give examples of what I have done and, if beneficial, quote authoritative references. And, since I have been an electrician, an industrial controls specialist and designer, engineer, engineering manager and project manager during my 40 year carreer I have usually done something similar to just about everything I read soI feel ”qualified” to comment.
I ran across an interesting post on the ASHI (American Society of Home Inspectors) site. I will reference it here:
” The word today is subpanel. Try to find it in an authoritative reference. It’s not in the National Electrical Code (NEC). It’s not in the International Residential Code, although the term sub-panelboard appears in two Figures in the Commentary. It’s not in the American Heritage Dictionary, nor is it in the Dictionary of Architecture and Construction. While widely used, this word does not exist, at least according to references approved by The Word’s Resident Librarian and Grand High Arbiter of Authoritative References.
This situation creates two questions. If you replace the word subpanel, what term do you use? If you use the word subpanel, how do you spell it? The Word gets a spelling error message in Microsoft Word when he types subpanel.
The word subpanel is a compound word that comes from the words subordinate and panelboard. The problem with the word subpanel is that every panelboard downstream from the service equipment and in the same building is treated as if it were a subpanel. This is true even if there is only one panelboard in the electrical system. If the first panelboard in a system is a subpanel, then what do you call a panelboard downstream from the first? Perhaps it is a sub-subpanel? This confusing situation is, no doubt, why the NEC does not use the word subpanel.”
And I might point out that I said you have to meet the local code requirements for what ever you install.
I will agree, there is way too much advice being given by folks who are not qualified, but then again, everyone has an opinion and the right to express it.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
showing 1 through 15 of 77 replies
