Sketchup 2017 Cutlist plugin?
Forum topic by bbasiaga posted 01-26-2018 01:20 PM 570 views 0 times favorited 6 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1240 posts in 2195 days
01-26-2018 01:20 PM
Topic tags/keywords: sketchup plugin cutlist
I have just upgraded my computer and installed the 2017 Sketchup.
I have used Sketchup for years, and really become a fan of the ‘Cutlist plugin. It will lay your parts out on lumber and calculate board feet. If you name a part with the word “sheet” in it, it will be able to lay those out on plywood for you at the same time.
This plugin does not seem to work with 2017 Sketchup. I am crushed.
Do any of you know of another plugin with the same functionality?
Brian
View lew's profile
lew
12428 posts in 3955 days
#1 posted 01-26-2018 03:53 PM
Mine works. It is cutlist V. 4.1.12 on Sketchup Make 2017
View Lazyman's profile
Lazyman
2619 posts in 1587 days
#2 posted 01-26-2018 04:15 PM
Works fine for me too—same version as lew. If you had an older version installed and working first (probably not if you are installing on a new computer), I think that you may have to reinstall or enable plug-ins when you install a new version of Sketchup. In fact, mine prompts me every so often telling me that there are plug-ins that need to be enabled.
Note: I just looked at Cutlist in the Extension Warehouse and it says it is compatible with the 2017 version.
bbasiaga
#3 posted 01-26-2018 04:29 PM
Hm..funny. when I go in to the library it shows it is installed, but it does not show up in my extension manager. If I click uninstall in the extension manager it just says it can’t uninstall for some reason (yes, those exact words!).
I will have to try and get my hands on the file ijtself and see if I can manually install maybe.
Brian
View lew's profile
lew
#4 posted 01-26-2018 04:34 PM
Maybe download it again then use the .rbz installer. The installer is located on the menu bar at Extensions/Plugin extension loader/Install single plugin/extension
Lazyman
#5 posted 01-26-2018 04:35 PM
This link may help:
https://help.sketchup.com/en/article/3000330
bbasiaga
#6 posted 01-27-2018 12:47 AM
Thanks guys. I was able to go on another computer and download the .rbz file, then install it manually. Seems to have done the trick. I am whole again!
Brian
