Mirka Abralon v. SIA Air
Forum topic by Mary Anne posted 03-30-2011 01:20 AM 2871 views 1 time favorited 12 replies Add to Favorites Watch
View Mary Anne's profile
Mary Anne
1058 posts in 3205 days
03-30-2011 01:20 AM
Topic tags/keywords: question sander sanding discs
I thought I found a pretty good deal on Abralon sanding discs . Well, the place I ordered from sent me some of the grits I ordered in Abralon discs, and some grits in SIA Air discs. I am not at all happy with the substitution without getting an okay from me, but now that I have them, I am curious if the SIA discs are an equal substitute.
The major difference is that Abralon is made with Silicon Carbide and SIA discs are made with Aluminum Oxide. According to Mirka, manufacturer of Abralon, “Aluminum Oxide grains plough into soft wood types” and “Silicon Carbide grains cut through hardwood.” In the microscopic picture the Silicone Carbide surface looks smoother.
SIA Air discs are distributed by Brunswick Bowling and the “experts” on the bowling forums swear by them, saying they last much longer than Abralon when used for polishing bowling balls. SIA discs can also be purchased from Grizzly, but Abralon is much more common on the other woodworking suppliers websites I visited.
Considering my skill level, this is unlikely to make much difference in my work, but I am curious anyway. What do you folks think? Would there be a detectable difference in the results between using Silicon Carbide or Aluminum Oxide? What are the plusses and minuses of using one or the other? Are Abralon and SIA close enough to considered the same even though they are composed of different materials, or is one significantly superior for woodworking?
12 replies so far
13603 posts in 3338 days
#1 posted 03-30-2011 01:25 AM
don’t know SIA
i use mirka
the best i’ve found so far
for roughly $50 a box of 100
i’m not about to shop around to much
so am anxious to see what others have to say
16274 posts in 4215 days
#2 posted 03-30-2011 01:44 AM
I’m in the same boat with David.
View SPalm's profile
SPalm
5320 posts in 3879 days
#3 posted 03-30-2011 01:44 AM
Ummm. I don’t know either.
But I will subscribe to this here list and I bet I will find out.
Steve
-- -- I'm no rocket surgeon
#4 posted 03-30-2011 01:50 AM
hey charlie
did you bring the bait
i brought the beer
correction:
just checked woodworkers supply
not $50
but $32 for a box of 60 grit gold mirka
which i will order now
View sedcokid's profile
sedcokid
2731 posts in 3595 days
#5 posted 03-30-2011 03:05 AM
I am in the same boat with SPalm, I am hoping to find out…
Thanks for posing the question
-- Chuck Emery, Michigan,
SPalm
#6 posted 03-30-2011 04:09 AM
I wonder if you made a really big Ort, could you use it for a boat?
Then we could all be in it together.
BarbS might know.
TopamaxSurvivor
18269 posts in 3673 days
#7 posted 03-30-2011 04:21 AM
Thanks for the question Mary Anne. This is what I love about LJ, learn things I didn’t even know to ask ;-)
View Bob Kollman's profile
Bob Kollman
1798 posts in 3188 days
#8 posted 03-30-2011 08:36 AM
I order all my sanding disc from Industrial abbrassive $12.50 for 50 sanding disc.
It’s rhino brand. Have no idea about it’s make up- It works-it’s cheap-and it works!!!!
-- Bob Kenosha Wi.
View tdv's profile
tdv
1188 posts in 3067 days
#9 posted 03-30-2011 09:57 AM
Sorry Mary Anne this boats fast becoming an ARK my knowledge of abrasives ( apart from grits)extends to “Does it remove wood?” “Yes!” “I’ll take a pack”
watching intently Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
Mary Anne
#10 posted 03-30-2011 05:26 PM
Well, guys, nice to know I am not the only one in the boat! Sanding and finishing is so important to our craft, someone out there must surely know something about grits and their make up and how they affect the final finish. It seems to me that the harder material (Silicon Carbide ?) would be best at giving the cleanest finish.
In the meantime I can think of no better company for a boat ride than you fellas… as long as we are not up the proverbial creek and someone remembered the paddle, we’ll be okay. :)
Bob Kollman
I shop at Industrial Abrasives as well and use their papers on all my sanders, but they don’t offer anything comparable to Abralon. Abralon and SIA are foam backed extremely fine grit sanding discs, ranging up to 4000 often used for rubbing out or polishing finishes.
Bob Kollman
#11 posted 03-31-2011 07:30 AM
Mary, I ve seen abralon there, but in small quanities, they also have sctoch brite.
It’s in an obsure area or catagory.
-- Bob Kenosha Wi.
View Greedo's profile
Greedo
473 posts in 2957 days
#12 posted 03-31-2011 07:58 AM
do you mean Siarexx from switzerland? thats the brand i use. well theres nothing else available in larger quantities here, but it’s good for the price.
