Sharpening stone honing oil advice
« back to Hand Tools forum
Forum topic by jtrz posted 01-25-2018 09:47 PM 1766 views 0 times favorited 24 replies Add to Favorites Watch
View jtrz's profile
jtrz
162 posts in 1377 days
01-25-2018 09:47 PM
I just got this set of 3 arkansas stones from Best Sharpening Stones but I forgot to order any honing oil.
I know I can order the honing oil that best sharpening stones sells but I was wondering if anyone has a prefered honing oil or if there is another type of oil (like mineral oil) that I can use and get the same or similar results.
If you have these particular stones I’d be interested to hear what you find works best on them.
Thanks
-- Jeff | Louisville, Ky
24 replies so far
View Andre's profile
Andre
2223 posts in 2010 days
#1 posted 01-25-2018 10:29 PM
3 in 1 works just fine, I did try some Norton, seems a little thinner?
View jtrz's profile
jtrz
#2 posted 01-25-2018 10:38 PM
I’ve read that 3 in 1 in time will clog up the stone. I think they said because of its thickness.
I’ve read that mineral oil works really well. Some people mix it 50/50 with kerosene or I think mineral spirits.
I am new to oil stones so bear with me but what is best practice after you are finished sharpening? Wipe the stone off? Rinse it off?
Thanks for the reply
View Woodknack's profile
Woodknack
12431 posts in 2584 days
#3 posted 01-26-2018 01:30 AM
3N1 is lightweight machine oil, about 17W, IIRC. Be fine. I use combination of motor oil and kerosene as an all purpose lubricant.
View mel52's profile
mel52
587 posts in 468 days
#4 posted 01-26-2018 01:54 AM
Anything that floats the metal residue of your sharpened edge off the stone should work. I have been using the oil that I put in my air tools. For some reason I have extra bottles of it and it seems to work good. When finished I put a little extra on the stone, rub it around with my finger and then wipe it off.
-- MEL, Kansas
View jtrz's profile
jtrz
#5 posted 01-26-2018 01:58 AM
I guess I’ll just have to test them all out and see what works best for me. I actually have some of that oil for air compressors. I’ll sharpen a chisel or two tonight and let you all know how it turns out
Thanks
View MagicalMichael's profile
MagicalMichael
117 posts in 720 days
#6 posted 01-26-2018 02:09 AM
As far as i can tell the only thing to avoid is something thick. I have tried hi end honing oil and also used very inexpensive lamp oil and haven’t been able to tell any difference.
Michael
-- michael
View Planeman40's profile
Planeman40
1307 posts in 2965 days
#7 posted 01-26-2018 02:58 AM
I’ve been using 3 in 1 oil for years with my Arkansas stones for years with no problem. I view the “3 in 1 oil clogs up the stone” an old wife’s tale.
View jtrz's profile
jtrz
#8 posted 01-26-2018 03:53 AM
Planeman40
Do you mix the 3 in 1 with kerosene as well.
Is the point of mixing the 3 in 1 to dilute or thin it out or does kerosene have some chemical properties or something that make the solution more effective?
I don’t have any kerosene right now, is there anything else I can use in it’s place?
Is mixing the the oil with something else absolutely necessary?
Also, I noticed that the wood base the stone is glued to is unfinished and is already getting dirty. After I actually start using these stones the bases are going to be filthy. Am I crazy in thinking about putting some protective finish on them so they don’t get soaked with oil and tiny metal particles?
Planeman40
#9 posted 01-26-2018 04:13 AM
I can’t comment on the mixing with kerosene as I never do it . I just use 3 in 1 oil as it is. I have a number of Arkansas stones with one about a foot long that cost me around $80. I am a real fan of them and prefer them for my final sharpening before proceeding with stropping. I use other coarse stones prior to the Arkansas for shaping and coarse sharpening. As to the glued down stones, I try to avoid them for just the reason you mention. If the idea of a dirty oil soaked wood base bothers you, then by all means apply some varnish on them. However the dirty wood bases don’t hurt anything. As a side note, I have moved sway from water stones as they are very messy and their softness allows wear to destroy their shape. But they do sharpen well.
View OSU55's profile
OSU55
1976 posts in 2193 days
#10 posted 01-26-2018 01:08 PM
Used lamp oil for many years
Andre
#11 posted 01-26-2018 01:45 PM
Oil stones can be washed out with warm soapy water and plastic brush, flushed well then re-oiled after they dry. Some people spray them down with WD-40 or rinse in kerosene? Same as a water stone they will need to be flattened at some time in there life, sooner if you sharpen a lot of narrow chisels and form groves.
Woodknack
#12 posted 01-26-2018 06:30 PM
Before you get analysis paralysis, just grab some 3n1 and go for it.
View jopo's profile
jopo
40 posts in 1439 days
#13 posted 01-26-2018 06:48 PM
- Rick_M
Analysis paralysis…I love that so much.
View bbasiaga's profile
bbasiaga
1240 posts in 2199 days
#14 posted 01-26-2018 08:08 PM
Hoppes gun oil, just the plain oil not the cleaning solvent, is pretty darn good as well. You can find it at a lot of sporting goods places like Bass Pro, Cabelas, Dicks, if you are not keen to go to a shooting store.
Brian
Woodknack
#15 posted 01-26-2018 08:37 PM
I read someone the other day talking about the difference between pre-internet and post internet woodworking. Pre-internet we would read a book and do that, or ask someone knowledgable and do that. Now we ask a hundred random people and get 50 different answers and can’t decide between them.
