Do you like them Thick or Thin?
Forum topic by LeviStarkey posted 03-30-2011 01:08 AM 1292 views 0 times favorited 16 replies Add to Favorites Watch
View LeviStarkey's profile
LeviStarkey
16 posts in 2581 days
03-30-2011 01:08 AM
Topic tags/keywords: question tablesaw
Do you like them thick or thin? I’m talking about table saw kerfs. My question is why would you want a thicker blade? I have a 3 hp saw. I am sure it would take all I give it; it takes the dado blades. What are your guys opinions on table saw blades?
16 replies so far
View Loren's profile
10244 posts in 3611 days
#1 posted 03-30-2011 01:21 AM
Standard width blades flutter less than thin kerf blades, which sacrifice
stability for more cutting power in 110 volt saws.
View bhog's profile
bhog
2236 posts in 2653 days
#2 posted 03-30-2011 01:25 AM
I prefer a thin kerf blade and that is what is usually in my table saw.I do own thicker kerf cross cut blades but anymore leave them in their packaging.I leave the thin kerf in because I find it more of a jack of trades blade.
-- I don't drive a Prius.
View drewnahant's profile
drewnahant
222 posts in 3052 days
#3 posted 03-30-2011 01:26 AM
because they flutter less, and do not distort as easily, I lik standard thickness blades for most cuts, I really only use a thin kerf for veneer cutting, and small, delicate work. removing the extra wood does take more power, but it only slows your cut a tiny bit, and gives a cleaner cut.
13600 posts in 3304 days
#4 posted 03-30-2011 01:47 AM
thicker for me
stiffer cut
and i can move the fence
and keep better score
of 1/8” increments
than those .oblah numbers
View jeepturner's profile
jeepturner
939 posts in 2755 days
#5 posted 03-30-2011 01:50 AM
I have never used a thin kerf blade. I never wanted the extra math when figuring waste. Also like David, it’s easier to move my fence to eighth inch increments.
-- Mel,
View bigike's profile
bigike
4050 posts in 3251 days
#6 posted 03-30-2011 01:54 AM
i like em thick but when ripping thin is good
117060 posts in 3540 days
#7 posted 03-30-2011 01:55 AM
I use both
View knotscott's profile
knotscott
7980 posts in 3338 days
#8 posted 03-30-2011 02:58 AM
Both. Which width to choose depends a lot of your saw and the material being cut. I’ve used both and had excellent results from both, but I gravitate toward high quality blades. I wouldn’t expect much from a mediocre quality full kerf blade, and even less from a TK. Now that I have a 3hp saw, there’s less incentive to use thin kerf, but when I had smaller saws, a good TK is a real blessing when hogging thru thick wood, and spares strain on the motor.
Even though the width differences appear very small, a full kerf blade is typically 33% thicker than it’s TK counterpart, and requires more power to spin. Full kerf blades tend to be more stable than TK blades, but that doesn’t mean TK blades are unstable…they’re not…high quality TK’s tend to be very stable. I’ve never had issue with a TK fluttering with or without a stabilizer, but a lot depends on the saw. A saw with runout issues using a cheap TK is very likely to have some flutter issues. A high quality thin kerf blade with proper tensioning of the body during manufacturing will rival the cut quality and performance of a high quality full kerf blade, and can be a very suitable choice for a home shop, smaller saws, and even in many commercial settings where wood consumption is a concern. The heavier mass of a full kerf plate will handle the stresses of heat better than a TK blade, so is often a more suitable choice for high volume applications.
There are legitimate arguments for both kerf widths, and the choice will come down to your personal preference and circumstances.
View StumpyNubs's profile
StumpyNubs
7578 posts in 2763 days
#9 posted 03-30-2011 03:07 AM
Thin is great for ripping. Thick is great for finish cuts. A good full kerf flat grind is also essential for specialty cuts that don’t go all the way through but don’t require a dado set.
When it comes to saw blades, get the best you can afford and read up on the different types. It’ll make a world of difference in your work!
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View William's profile
William
9949 posts in 2805 days
#10 posted 03-30-2011 04:16 AM
I like thin, but don’t use them. Why you ask?
I have a Rigid 3650. With a thin kerf blade, the wood hangs up on the splitter. I’ve read articles on sanding the splitter down to allow for thin kerf blades, but as long as the saw is handling the standard blades fine, I think I’ll keep doing what I’m doing.
View richgreer's profile
richgreer
4541 posts in 3037 days
#11 posted 03-30-2011 04:36 AM
I prefer thin with a stabilizer. The stabilizer keeps the flutter down, but limits how deep you can cut. 99.9% of the time that is not a problem. If it is a problem, I can remove it for the cut.
View ScottN's profile
ScottN
261 posts in 2642 days
#12 posted 03-30-2011 02:37 PM
I’m with patron 1/8” for easy figuring.
-- New Auburn,WI
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3121 days
#13 posted 03-30-2011 05:12 PM
I’m in the market for a regular kerf blade (or two) now. It will make measurements on the outside of the blade much easier knowing the blade is exactly 1/8”.
I can probably live without the flutter with a thin-kerf blade, but then again, it’s been so long since I’ve actually used a regular kerf blade on the table saw that I’m sure I don’t even see it as a negative right now. I’m sure I’ll notice the difference once I pop for the regular kerf blade.
-- jay, www.allaboutastro.com
Cosmicsniper
#14 posted 03-30-2011 05:16 PM
Oh, BTW, I showed my wife the title of this thread…she said, “Oh honey, it’s not the size that matters, it’s the way that you use it.”
Didn’t know she understood that much about my hobby. :)
View HorizontalMike's profile
HorizontalMike
7749 posts in 2877 days
#15 posted 03-30-2011 05:26 PM
Well someone has to say this:
MY THICK-KERF BLADES MATCH MY RIVING KNIFE.
For me it started out as a safety issue with my G0690 where the manual clearly states such. Now, the other comments above about increased stability and easier math are just added benefits.
