Does anybody know how to get a finish like Treefrog Salsawood Laminate but on wood?
Forum topic by Weldwood posted 01-25-2018 06:33 PM 1247 views 0 times favorited 2 replies Add to Favorites Watch
View Weldwood's profile
Weldwood
1 post in 143 days
01-25-2018 06:33 PM
Topic tags/keywords: wood stain trick technique finish
2 replies so far
View waho6o9's profile
waho6o9
8205 posts in 2599 days
#1 posted 01-25-2018 06:59 PM
Cut out bristles in several paint brushes and have at it.
Use a solid base coat like red, then paint on top of that.
If I understand you correctly.
View John Smith's profile
John Smith
989 posts in 185 days
#2 posted 01-25-2018 07:33 PM
several passes with different colors of paint. allow to dry and lightly sand between coats.
plus any additional tools to achieve the end results that you are expecting.
the most satisfactory results will be achieved on flat panels. if this effect is required on rounded edges
or complex curves, testing and experimenting may be required to obtain satisfactory results.
-- Graduated Valedictorian from the University of HardKnocks --
