Band Saw or Bandsaw? And, do you really need a quick release?
Forum topic by StumpyNubs posted 03-29-2011 07:48 PM 6308 views 0 times favorited 51 replies Add to Favorites Watch
View StumpyNubs's profile
StumpyNubs
7578 posts in 2765 days
03-29-2011 07:48 PM
Seems like whenever I do a band saw related search on the internet the search engine corrects me. if I search “Band Saw” is asks “Did you mean bandsaw” But if I type “Bandsaw” it wants to know if I meant the other way. I can’t seem to get it right. so let’s settle this once in for all- What the heck is the correct way to spell it?
Of course that wasn’t the only reason for this thread. I want to talk about Band Saw/Bandsaw quick release mechanisms. Carter makes a nice one for about $150- which is an outrageous price. And since there has been a long debate over weather they are necessasary at all, I thought I’d ask the community.
I am filming one of the upcoming episodes of the Stumpy Nubs Show which will include my own design for a homemade quick release, but I wanted to know if anyone really even wants one.
Here’s what i see as the two sides of the issue:
ONE SIDE SAYS- Leaving your blade tensioned all the time causes it to develop a “memory” and will leade to reduced flexability and shorten it’s life. It can also cause flat spots of the tires. A quick release makes it easy to release tension between uses, and also makes blade changes faster.
THE OTHER SIDE SAYS- That’s a bunch of whooey! People have left their band saw tensioned for generations and those things rarely happen. If you change blades a lot, or have a hundred and fifty bucks burning a hole in your pocket you can get one. But my tires and blades will last just as long as yours.
SO- which side do you come down on?
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
51 replies so far
View superstretch's profile
superstretch
1531 posts in 2658 days
#1 posted 03-29-2011 07:58 PM
Table saw, scroll saw, hand saw, dovetail saw, chain saw=> ergo band saw.
Cheapo Craftsman 10” bandsaw with a $10 blade. You can bet I don’t un-tension it after every use…
-- Dan, Rochester, NY
View Bill White's profile
Bill White
4902 posts in 3925 days
#2 posted 03-29-2011 09:14 PM
I de-tension from habit. Never had a failure before doing same (or since).
Bill
-- bill@magraphics.us
View Bertha's profile
Bertha
13521 posts in 2658 days
#3 posted 03-29-2011 09:20 PM
I never detensioned mine (which I killed in an unrelated event). I’ve seen many homebrewed jobs around. $150 is pricey, but it IS a Carter product. I noticed the same thing in google. Bandsaw like bowsaw, iMHO.
View crank49's profile
crank49
4030 posts in 2936 days
#4 posted 03-29-2011 09:42 PM
Dan, which cheapo Craftsman 10”? I have one that’s a rebadged Rikon. I love that little saw.
Jim or should I say Stumpy? I don’t think a failure to de-tension a band saw blade is going to foretell the end of life as we know it, but it can’t hurt anything either; unless you forget to re-tension before the next use.
StumpyNubs
#5 posted 03-29-2011 09:57 PM
Crank- That’s a good point. Using a bandsaw tension release can cause you to forget to re-tension before you turn it back on. I doubt that would be catastrophic, but what a mess it would cause!
Of course, the Carter tension handle is designed to remind you to retighten because it has a big red grip on the end which hangs down in your face when the tension is released. Home made versions don’t usually have that.
Everyone seems to say- why not have one. I can think of a couple reasons not to- 1. Price, 2. Price and 3. Price. If I bought every do-jiggy on the market for every tool I’d be broke. So before anyone slaps down the big bucks, it better have an upside that makes it worth the price.
I have yet to hear of anyone who has ever confirmed that NOT releasing the tension between uses has damaged anything. So seems to me that it is a waste of money.
Of course, if someone gave me one I’d use it!
superstretch
#6 posted 03-29-2011 10:02 PM
@Crank- I have a newer model. Picked it up new after not seeing anything on CL for a while and needed one sooner rather than later. It was on sale, so why not. I wish I had had the $ at the time to go bigger.. Resawing a max of 4-5/8” is pretty lame.
@Stumpy- Honestly, I think the blade will dull and the tire bearings go bad long before you’d see the effects of not de-tensioning. Perhaps I’m wrong, but it sounds logical in my head
View BilltheDiver's profile
BilltheDiver
253 posts in 2850 days
#7 posted 03-29-2011 10:10 PM
I have the Carter and use it! Sure makes changing blades a lot easier and quicker. I’m not so sure it is too important to de-tension if you mostly use larger blades for resawing, but if you do much with 1/4 or 1/8 inch blades I think it is more important.
-- "Measure twice, cut once, count fingers"
Bertha
#8 posted 03-29-2011 10:10 PM
I always imagined that all but two small parts on the tires would be under continuous pressure, and thus could potentially deform. Tires are relatively cheap, though. I’ve started my saw many times in a detensioned state. Mostly, it would just make a terrible noise; once it broke a thin blade but kept it retained within the saw. When I buy my new saw, I’ll probably spring for one. But I’m with you, it’s like buying an air filtration unit: it hurt, it wasn’t any fun to play with, but it seems like the right thing to do.
View TheDane's profile
TheDane
5399 posts in 3628 days
#9 posted 03-29-2011 11:01 PM
First, I have read the pros and cons of de-tensioning the band saw blade, and go with those who say you should do it. My neighbor doesn’t … when he starts up his band saw, the tires are in such bad shape it sounds like a corn sheller and vibrates all over the place.
I have the Carter system on my Jet 14”, and it is great … I find myself using the band saw now more than before I installed the Carter, and it does make blade changes a lot faster. My band saw purrs like a kitten.
—Gerry
View saddletramp's profile
saddletramp
1180 posts in 2603 days
#10 posted 03-29-2011 11:49 PM
Well, Stumpy, before this discussion I really had no opinion one way or the other on this issue. I had heard both sides before but no compelling arguments for either side. I sometimes detensioned mine and sometimes I didn’t. LOL Now, however, after hearing from both sides here, I still have no opinion one way or an other. LOL
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
StumpyNubs
#11 posted 03-29-2011 11:56 PM
TheDane- Are you certain that your neighbor’s problem is because he didn’t use a tension release? I ask because it would be the first time I have ever heard a real example of someone who had a problem because he kept it tensioned all the time. I hear a LOT of “if’s” and “could’s” from people, especially companies who make them….
I suppose it would make sense that a thin blade would be more likely to weaken if always kept tensioned, and a wide blade may be more likely to flatten a tire because it has to be under a lot more tension than a narrow blade. And I suppose if you kept a blade tensioned for a very long time (years) without turning on the saw it may be more likely to cause problems. But if you’re using the saw several times a week, I don’t know. Unless the horror stories we her about actually happen, isn’t it more about speculation than reality?
saddletramp
#12 posted 03-29-2011 11:56 PM
BTW the Merriam-Webster dictionary says Band saw is correct, the Oxford English dictionary says that either is correct.
TheDane
#13 posted 03-30-2011 12:07 AM
StumpyNubs—Am I certain? No, but the tires on my saw are smooth, while the tires (especially the top wheel) on his saw feel like snow tires. You be the judge.
—Gerry
View GaryL's profile
GaryL
1099 posts in 2795 days
#14 posted 03-30-2011 12:11 AM
I back off the tension with four or five cranks on the tensioner wheel and call it good. Save that $150 for something else. The three or four seconds it saves does not seem worth it to me.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2879 days
#15 posted 03-30-2011 12:12 AM
I tend to believe the flat tire story on the BSs. I do know that my little Toyota truck only gets fired up every couple/three weeks and when it does, the first 10-20 miles down the road shakes like crazy until the tires warm up and expand. I don’t really plan to have to run my BS for a half-hour to get it to stop shaking so I de-tension my BS between uses. Forgot to re-tension once but no problems, just spinning wheels and the blade came off the wheel without damage. Woke me up though ;-)
showing 1 through 15 of 51 replies
