new to woodworking with question
Forum topic by DWoodhead posted 01-24-2018 01:20 PM 722 views 0 times favorited 16 replies Add to Favorites Watch
View DWoodhead's profile
DWoodhead
3 posts in 174 days
01-24-2018 01:20 PM
I am new to woodworking. I am trying to learn how to purchase lumber. I kind of understand the formula for calculating board ft. However, I am confused with the answer I get when I try to figure it out. My question is simple. If I am trying to buy (10) boards that measure 1”x4”x10ft how many board feet is that for all 10 boards? Sorry for the dumb question but any answer would be greatly appreciated. Maybe once I know the answer I can figure it out on my own from there.
16 replies so far
View Ron Aylor's profile
Ron Aylor
2634 posts in 671 days
#1 posted 01-24-2018 01:28 PM
- DWoodhead
((1×4 x 10) / 144) x 10 = 33.33 bft
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
View Holt's profile
Holt
258 posts in 2652 days
#2 posted 01-24-2018 01:30 PM
One board foot is a piece of wood one inch thick and twelve inches on each side.
So for your board 1” =1
4” = 1/3 of a foot
10 ft = 10
So 1×1/3×10 = about 3.33 board feet.
-- ...Specialization is for insects.
View jmos's profile
jmos
839 posts in 2393 days
#3 posted 01-24-2018 01:37 PM
A couple things to keep in mind:
Dimensional lumber, or construction lumber, is different – if your buying 2×4’s they are sold by the linear foot, and they are not actually the dimensions stated (a 2×4 is 1.5”x3.5”.)
For hardwood, the thickness is nominal, so if your buying hardwood that has been surfaced on 2 sides (S2S), the thickness will be less than the nominal size listed (say 7/8” think for a 4/4 board) but you pay for the full 4/4. The place I used to buy from I was lucky if I could get a 4/4 board that was actually 3/4” thick.
-- John
View tomsteve's profile
tomsteve
790 posts in 1242 days
#4 posted 01-24-2018 01:48 PM
1” times 4” times 120”(10’) =480 cubic inches.
divided by 144= 3.33 cubic feet or 3.33 board feet per board.
3.33 bd ft times 10 boards=33.33 board feet total
board foot is simply cubic feet splained differently
theres board foot calculatin machines available on the WWW to use for free,too.
oh, and welcome to the forum.
View gargey's profile
gargey
995 posts in 799 days
#5 posted 01-24-2018 02:06 PM
333.3 board feet.
View bondogaposis's profile
bondogaposis
4757 posts in 2374 days
#6 posted 01-24-2018 02:08 PM
It is easier to think of a board foot as 144 cubic inches, forget about the 12”x12”x1” nonsense. The easiest way to calculate is: (length in inches x width x thickness)/144= bf. I used to pack a small calculator to the lumber yard, now I have a phone that can calculate.
-- Bondo Gaposis
View CaptainKlutz's profile
CaptainKlutz
278 posts in 1517 days
#7 posted 01-24-2018 04:00 PM
Entire “board foot” measurement can be daunting even when you understand it!
Much simpler approach to buying wood is: #1 Visit favorite lumber store,
pick out enough nice looking boards to make your project (adding extra 10-15% for inevitable mistakes),
let nice check out person measure and calculate the bdft, then
pay them what they require to leave store with your wood.
Works for me. :)
PS – the inch to foot conversion is only hard part. One trick when picking boards that are roughly same length, use tape measure and keep adding together all the widths recording final measurement in feet, then measure length in feet and multiply length/width (4/4 lumber). If buying 6/4 or 8/4 lumber need to multiple by 1.5 or 2 for extra thickness.
Best Luck.
DWoodhead
3 posts in 174 days
#8 posted 01-24-2018 07:55 PM
Guys, I want to thank all of you for your quick response and very thorough and helpful answers. I have a really good idea now of how to move forward with future purchases. This was my first post to this forum and I am overwhelmed with the responses and the willingness of so many people willing to help out a new person getting into woodworking. Again, thank you all and I truly appreciate everyone’s response.
View dbray45's profile
dbray45
3320 posts in 2800 days
#9 posted 01-24-2018 08:22 PM
Other things to keep in mind
If you buy 8” wide lumber, allow for the ripping and jointing of both boards.
Watch for cupping and twisting – if you rip the boards smaller and glue them to flatten them, you also lose width as well.
Watch the ends for checking and splits and plan what you will cut on what boards.
Rule is that if you buy exactly what you need, you will not have enough.
-- David in Damascus, MD
View Vindex's profile
Vindex
91 posts in 845 days
#10 posted 01-29-2018 08:39 PM
I use this excel spreadsheet from woodworkerssource: https://www.woodworkerssource.com/help/Project-Planner-Board-Feet-Calc2.xlsx
It calculates the board feet for me.
View Lazyman's profile
Lazyman
2043 posts in 1410 days
#11 posted 01-29-2018 08:52 PM
1” times 4” times 120”(10 ) =480 cubic inches.
- tomsteve
Just a small correction to the bolded line above. You are correct that it is 3.33 board feet but board feet are not equivalent to cubic feet. There are 12 board feet (12”x12”x1”) per cubic foot (12”x12”x12”)
View Drew's profile
Drew
350 posts in 3123 days
#12 posted 01-29-2018 10:17 PM
- DWoodhead
- Ron Aylor
This is not correct.
((1×4 x 120) / 144) x 10 = 33.33 bft is correct. Or ((1×4 x 10) / 12) x 10 = 33.33 bft
Or better yet:
Length (1200) x width (4) x thickness (1), all in inches, divided by 144.
-- TruCraftFurniture.com
View Walker's profile
Walker
135 posts in 495 days
#13 posted 01-30-2018 12:55 AM
I usually just google “Board Foot calculator”, click on the first result, then plug the numbers in.
http://extension.missouri.edu/scripts/explore/G05506.asp
Most of the time I go with Captain Klutz’s method, but sometimes I want to know the price of a project before buying anything.
-- ~Walker
View ScottM's profile
ScottM
654 posts in 2170 days
#14 posted 01-30-2018 01:26 PM
Most of the time I go with Captain Klutz s method, but sometimes I want to know the price of a project before buying anything.
- Walker
I use this one a lot when comparing prices between one who sells by board foot and one who just sells the board for a flat price or linear foot.
View Tennessee's profile
Tennessee
2873 posts in 2537 days
#15 posted 01-30-2018 01:48 PM
The board feet answer has been thoroughly covered, but you can buy lumber three ways, actually.
If you get on Craigslist and go to Materials, then type in Lumber, you’ll see a lot of different people selling lumber a lot of ways.
By the board foot, the most common and what was explained here.
By the Linear foot, which is 12” of the plank, no matter how thick or how wide it is. Just the length. Sometimes, this can be a real bargain, but always have your phone with your calculator out to do the board foot calculation so you can see how much they are really charging for the board foot price. 12” of a 4” wide board may not be any bargain, but 12” of a 14” wide board probably is a real bargain. I’ve bought a lot this way, cash in hand.
By the load. Sometimes, this is the absolute best way to buy lumber. A HUGE load I bought some off of a month or two ago just got sold around me here. (In St. Elmo, Chattanooga). He had about 1800 board foot, total, of walnut, cherry, oak and hickory. I know from picking through it that the hickory was junk, (full of powder post), but he had all remaining 1800 board foot up for $3600. Even if you gave him that, (and a lot of that lumber was really, really nice), that is a lousy $2 a board foot. BUT, if you walked up with say, $3000 or $3100, you might be able to grab it for a stupid wholesale price.
When I bought it, he had almost 3000 board feet in storage, and boy, that was some fine lumber. I just didn’t have any more money or space to store more than what I bought. He sold more to other people, than sold the remaining load for a real bargain.
I know when I bought from him, I cherry-picked about 130 board foot of walnut and cherry and a tiny bit of hickory for $350 total. That was $2.69 a board foot for top shelf nine year old planed on one side lumber, mostly a true 1” or 1 1/8” thick, random widths up to 13” wide, with most boards going 8-9 foot long. I took mostly the walnut, since it is the most expensive for me to buy anywhere else.
So there is always more than just the measurements! Bargains are out there, if you hunt….
