band saw question
Forum topic by harum posted 01-24-2018 03:34 AM 1124 views 1 time favorited 44 replies Add to Favorites Watch
View harum's profile
harum
280 posts in 1552 days
01-24-2018 03:34 AM
I’m new to band saws and looking for a suggestion on how to solve this problem. I’m trying to split/resaw a foot-long 1-1/2” x 3-1/2” board into two 3/4” x 3-1/2” x 1’ on a band saw. As soon as I start the cut the blade turns away from the fence entering the board at an angle and then in a second I smell burned wood, see smoke and then the blade may bind. On the photo below, the yellow line is parallel to the fence, the cut is angled away from fence. The cut height is 3-1/2”.
I’m using a brand new low tension Timber Wolf blade: 0.025” kerf, 1/2”, 3 TPI, hook tooth. I can do good straight cuts on a 5/8” thick board, either with fence or free-hand when the tension gauge is set to 3/8” or 1/2” marks. Here’s a free-hand cut:
I assume the blade is still sharp because it had only been used for a few minutes before. The blade tracks in the middle at the crest. The guides are 1/4” above the board. Should I try tensioning the blade up to the 3/4” mark or more? Or does this have anything to do with drift angle?
I would appreciate any suggestion on what else could be done here.
Thanks and best wishes, h.
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
44 replies so far
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#1 posted 01-24-2018 03:42 AM
First off, ignore the tension markings on your machine… those are there to get you in the ballpark only. Secondly, have you watched the obligatory band saw tune up video?
Band Saw Clinic with Alex Snodgrass
View John_H's profile
John_H
133 posts in 1615 days
#2 posted 01-24-2018 03:49 AM
Blade Tension
When I finally broke down a bought a proper ‘tension gauge’ I was surprised how under tension my blade was – yet I was using the chart and the marks that came with my bandsaw.
Unfortunately, a proper tension meter is quite expensive – around $300, although I was able to pick up a used one for about half that on eBay
example:
http://www.lenoxtools.com/pages/tension-meter.aspx
There are several youtube videos on how to make your own tension meter using a dial indicator you may want to look into or a lot of people use the ‘flutter’ test
https://www.youtube.com/results?search_query=bandsaw+tension+meter
Also a good video on how to set up the blade (Alex Snodgrass)
https://www.youtube.com/watch?v=wGbZqWac0jU&t=1074s
View AandCstyle's profile
AandCstyle
2979 posts in 2166 days
#3 posted 01-24-2018 10:32 PM
Harum, I have gotten good results using the Timber Wolf flutter test. HTH
-- Art
View Loren's profile
9981 posts in 3557 days
#4 posted 01-25-2018 12:45 AM
Perhaps the guides aren’t set close enough
to the blade sides. Perhaps there isn’t enough
tension.
View Andybb's profile
Andybb
758 posts in 512 days
#5 posted 01-25-2018 01:18 AM
Grab some scrap wood and a day and get to work AFTER you watch the Snodgrass video. Do exactly what he says as each and every step done correctly helps to eliminate problems. I am a relative novice also. More than any other tool I find that a BS is like a nervous system. You have a limp but it could be caused by a pulled muscle, a pinched nerve in your back or a brain tumor or any number of things which can cause any number of other things to be impacted. The flutter test is good but it is still subjective. After EVERYTHING is adjusted per Snodgrass try turning that tension up incrementally and testing it until it sounds like it’s slowing the motor. You might be surprised at how tight it’s supposed to be as John H said above. Bsaws are wonderful when they work but are a true PITA when they don’t. Like I said, get a bunch of scrap and set aside a whole day. Don’t even think about resawing until everything else is working perfectly.
JMHO
-- Andy - Seattle USA
View Knockonit's profile
Knockonit
301 posts in 111 days
#6 posted 01-25-2018 01:33 AM
It took me quite a few tries to get it right, on a delta 14’’, a new blade, tension adjusting, and guides adjusted right. a little frustrating, but with perseverance it will bear fruit,
I was so happy with my delta turning out so well, i did the same to the cheapo HF 14’’ unit, while it took a lot more effort, i did get it to where i can resaw up to 3/16’’ in a decent straight line, takes patience, but it will come about.
and once you do, its like you hear harps and stuff. lol
good luck,nothing like a tuned band saw.
runswithscissors
2657 posts in 1934 days
#7 posted 01-25-2018 01:44 AM
The best I was able to do only let me hear accordions.
harum
#8 posted 01-25-2018 01:44 AM
Thanks for the responses! Well, I’ve set up the saw once again following the video—nothing changed. 1” cuts are okay; the 3-1/2” cuts fail miserably.
Using “flutter” test I tensioned the blade until it stopped “fluttering” and then added an extra turn as suggested by the manufacturer but when cutting the blade still entered 3” boards at a shallow angle and didn’t straighten up until it bound. I kept increasing the tension until the blade has changed tracking and started hitting the aluminum blade guard. I re-checked and, yes, changing the tension changes the tracking of the blade—who knew! Will see if anything else could be done here (after I get a new blade).
Can I continue tensioning and adjusting the tracking? What breaks first, the band saw or the blade? The tensioning knob is getting hard to turn.
Perhaps the guides aren t set close enough
to the blade sides. Perhaps there isn t enough
tension.
- Loren
The guides on the right side wear pretty quickly. The blade twists and files down the coners.
Bsaws are wonderful when they work but are a true PITA when they don t.
- Andybb
Yes, kind of frustrating; this is a new 14” Jet and I haven’t been able to cut anything so far.
MrUnix
#9 posted 01-25-2018 01:58 AM
I kept increasing the tension until the blade changed tracking and started hitting the aluminum blade guard. I re-checked and, yes, changing the tension changes the tracking of the blade—who knew!
- harum
Something is not right with your machine… increasing tension should not alter tracking, and a blade rubbing against a guide block will not ‘file down the corners’ unless you have the teeth hitting it (which would also ruin your blade and cause it to pull to one side like you mention).
#10 posted 01-25-2018 02:02 AM
Check the tires for lumps. Hold something
like wooden skewer against the tire so it
just barely touches and rotate the wheel.
If the tires are lumpy this can be corrected.
harum
#11 posted 01-25-2018 02:14 AM
What kind of saw do you have?
- Loren
This is JET JWBS-14CS. The one that comes in two boxes.
Something is not right with your machine… increasing tension should not alter tracking, and a blade rubbing against a guide block will not file down the corners unless you have the teeth hitting it (which would also ruin your blade and cause it to pull to one side like you mention).
- MrUnix
Tension did change tracking on this saw: increasing the tension moved the blade forward, decreasing moved it back. When I tensioned the blade well above the 3/4 mark on the scale, the blade was about to slip off the wheel.
The blade twists as soon as it touches the wood and enters at an angle.
MrUnix
#12 posted 01-25-2018 02:18 AM
- harum
Check your upper wheel pivot bracket… sounds like it’s either bent or broken.
View mrg's profile
mrg
805 posts in 2908 days
#13 posted 01-25-2018 02:19 AM
How old is the saw? The casting for the upper wheel adjustment sounds like it may have broken. Take the blade off and remove the upper wheel, I will bet the hinge is cracked.
-- mrg
View JohnMcClure's profile
JohnMcClure
147 posts in 549 days
#14 posted 01-25-2018 02:22 AM
My blade always tried to pull the board away from the fence, if that makes sense. Angling through the workpiece. I eventually determined it was due to drift angle, and adjusted my fence to align with the natural drift instead of square to the blade. This was with a 3tpi 1” resaw blade sawing 12” diameter cherry logs into boards.
HOWEVER it may be something else, I’m fairly new to the BS too, I know there a lot of variables that can be adjusted.
-- I'd rather be a hammer than a nail
harum
#15 posted 01-25-2018 02:37 AM
Check your upper wheel pivot bracket… sounds like it s either bent or broken.
Do “upper wheel pivot bracket” and “upper wheel hinge” mean this thing?
showing 1 through 15 of 44 replies
