Table Saw
Forum topic by TheJoineryGallery posted 787 days ago 426 views 0 times favorited 3 replies Add to Favorites Watch
View TheJoineryGallery's profile
TheJoineryGallery
30 posts in 976 days
787 days ago
Hello all-
I was curious what some think to be the most bang for your buck when ripp 8/4 material?
-- www.thejoinerygallery.com
3 replies so far
View David Kirtley's profile
David Kirtley
1250 posts in 1169 days
#1 posted 787 days ago
A bandsaw :)
View therookie's profile
therookie
891 posts in 999 days
#2 posted 787 days ago
I use a 3hp table saw made by delta. Its not a unisaw but a contractors saw and as long as I keep my feed rate consistant I cant slow it down.
-- http://aewoodworks.webs.com
View knotscott's profile (online now)
knotscott
4208 posts in 1547 days
#3 posted 787 days ago
Best bang for the buck usually involves used tools. A well aligned 1.5 to 2hp full size contractor saw with a belt drive induction motor fitted with a good 24T thin kerf blade should do pretty well, and can often be found in the $200 range. A 15 amp jobsite saw will likely make the cut too but may not hold up as long, and has a much shorter table.
A BS will do the job too but the cut is typically rough enough to require some additional work to make smooth afterwards.
