anyone know what type of hand plane this is
« back to Hand Tools forum
Forum topic by jtrz posted 01-23-2018 08:23 PM 431 views 0 times favorited 4 replies Add to Favorites Watch
View jtrz's profile
jtrz
160 posts in 1348 days
01-23-2018 08:23 PM
I found these old planes for sale online and I’m trying to figure out if they are worth getting. The photos are what was posted online so forgive me for the bad quality.
First is a smoothing plane I assume but the lever cap and depth adjustment knob aren’t familiar to me
The next I think is a no. 7 jointer plane. The plane number on the toe has a diamond shape cast around it and I’ve never seen that before.
If anyone has any ideas let me know
Thanks
-- Jeff | Louisville, Ky
Smitty_Cabinetshop
15649 posts in 2793 days
#1 posted 01-23-2018 08:55 PM
Run away from that smoother, it’s a stamped steel frog variation that will frustrate you forever. It’s maybe a $5 curiosity, but it’s not a serious hobbyist tool.
The diamond emblem No. 7 is “Diamond Edge,” a Shapleigh hardware brand likely made by Stanley but they had more than one mfgr over the years. Looks good, but the hard rubber tote needs to be replaced as the horn is broken (typical on DEs).
The others look like one transitional jack, one skew rabbet plane, and one nosing plane. Of all them, I’d consider the skew rabbet first, then the No. 7 DE. I’d leave the rest to others.
View jtrz's profile
jtrz
#2 posted 01-23-2018 09:13 PM
Thanks for the reply. I figured the smoothing plane was junk. That frog looked pretty flimsy.
I really want a jointer plane so I might get that. Might be tough to find a new rubber tote though but I’ve never looked so what do I know.
Thanks for the help
Smitty_Cabinetshop
#3 posted 01-23-2018 09:16 PM
No problem, you’re welcome!
I’d suggest you can make a tote with some simple tools OR scavenge one. What’s on it will certainly work, too (shouldn’t have said it ‘needed’ to be replaced…).
View Don W's profile
Don W
18990 posts in 2743 days
#4 posted 01-23-2018 09:19 PM
I agree with Smitty, but you can also fix the tote with some epoxy and patience. Just mix some colored epoxy in a mold, with the tote in it. When it hardens shape it. I’ve never tried it because I’d prefer wood, but it’s an option.
