Looking for a pattern for hold down clamps
Forum topic by Vrtigo1 posted 03-29-2011 02:40 AM 33814 views 14 times favorited 12 replies Add to Favorites Watch
View Vrtigo1's profile
Vrtigo1
434 posts in 3229 days
03-29-2011 02:40 AM
Wondering if anyone has a pattern for a shop made hold down clamp similar to this commercial model from Rockler:
http://www.rockler.com/product.cfm?page=22010&filter=hold%20down
I figure I can probably come up with something but thought it would be easier if someone already did the leg work :)
Also, does anyone have any suggestions for sourcing T-track bolts locally? This is what I’m looking for:
http://www.rockler.com/product.cfm?page=1573&filter=t%20track%20bolt
I know I could order from Rockler, but figured it’d be worth it to save the $7 shipping cost on an $8 order if I could get them locally.
12 replies so far
View Viking's profile
Viking
880 posts in 3432 days
#1 posted 03-29-2011 02:51 AM
Here is an idea for shop made;
http://lumberjocks.com/projects/30083
You can use standard 5/16 bolts in most T-tracks.
Good Luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#2 posted 03-29-2011 03:40 AM
T track bolts are toilet bolts available at any hardware/big box store.You can get 1/4 or 5/16 in various lengths.
View tommyd's profile
tommyd
77 posts in 3369 days
#3 posted 03-29-2011 04:57 AM
http://lumberjocks.com/projects/16919
check this out
-- Life is too short for negative drama & petty things. So laugh insanely, love truly and forgive quickly!  http://tomswoodshop.etsy.com
View woodworkerscott's profile
woodworkerscott
361 posts in 3051 days
#4 posted 03-29-2011 05:03 AM
Here’s a pattern I like:
I also use toilet bolts.
Hope this helps!
-- " 'woodworker'.....it's a good word, an honest word." - Sam Maloof
View drewnahant's profile
drewnahant
222 posts in 3326 days
#5 posted 03-29-2011 05:12 AM
here’s some I made recently
maple and cherry, bar made from 1/2” bolt, cut and ground flat with an angle grinder, then drilled
View rance's profile
rance
4267 posts in 3398 days
#6 posted 03-29-2011 05:16 AM
Drew, such a nice clamp. Doesn’t seem right to have a plastic knob. :)
drewnahant
#7 posted 03-29-2011 05:21 AM
rance, I need to make some wood knobs, but the woodcraft knobs were only a buck each, so I figured they would be a good temporary fix so I can use the clamps until I get around to making a bunch of knobs
View Don's profile
Don
12 posts in 2858 days
#8 posted 03-30-2011 07:42 PM
A Q&D (quick & dirty) solution is a piece of scrap hardwood: 1/2” x 1-1/2” x 6”. Drill a hole in the center for a T-bolt. Add 100 grit sandpaper to both ends with double-sticky carpet tape. To use the hold down, you will need a piece of stock under the free-end, to match the height of your work piece.
Not what you would call an elegant solution – but it’s easy to make when you need something quick. I made a couple for a dedicated jig and have since borrowed them for other temporary jigs!
Last, but not least, a tip for low cost knobs for your jigs – lawn mower replacement handle knobs. The bolt/thread size is 5/16”, and they generally cost less than $3 a pair.
-- Don
View Bertha's profile
Bertha
13551 posts in 2930 days
#9 posted 03-30-2011 07:54 PM
Drew, I know it probably had to be done but seeing that gorgeous clamp over laminate is causing my neurons to fire abnormally. I really like the look of the trapped tapped bar. Fantastic idea that took quite a bit of work. I have a deep respect for all shop made tools.
Vrtigo1
#10 posted 03-30-2011 10:09 PM
Thanks for the comments and suggestions. Don, have you actually sourced these lawnmower knobs locally or is that just an idea that you had? I ask because I had a similar idea and found that nobody sells them. I haven’t checked a lawnmower repair place, but I checked all the big box stores and struck out. The closest place I’ve found is woodcraft, but it’s an hour drive for me. Last time I was there I bought 10 of ‘em and only have 3 or 4 unused so I’ll probably reload next time I’m in the area.
View Jim Crockett (USN Retired)'s profile
852 posts in 3970 days
#11 posted 03-31-2011 04:02 AM
Check out this link for shop-made hold downs.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
View Steve Adams's profile
Steve Adams
1 post in 1314 days
#12 posted 09-12-2017 09:54 PM
The best place I have found for T-Track is http://www.orangealuminum.com/t-slot-framing-systems-and-tracks/t-track.html. They use just common 1/4” hex head bolts or you can use Toilet bolts.
-- Steve, Homer Glen, IL
