What to do what to do
Forum topic by Deanoside posted 01-23-2018 04:44 AM 425 views 0 times favorited 3 replies Add to Favorites Watch
View Deanoside's profile
Deanoside
33 posts in 542 days
01-23-2018 04:44 AM
Hi guys quick question. Of them working on a piece of wood that I encased in a epoxy. I started out with the idea of doing a bench top.now that I am nearing completion I am torn on what to do with it. Should I hang it on the wall? Or should I continue on with the original plan of making it a bench?
As always your guys’s input is greatly appreciated thanks
-- A learning man is Alive a learned man is dead
3 replies so far
View msinc's profile
msinc
569 posts in 743 days
#1 posted 01-23-2018 01:11 PM
That’s neat…I like it. But then I like all things that are different or unusual. For what it’s worth, here is what I do when I have something unusual and am not sure what to do with it or what to make it into…I set it aside and give it some time. Eventually, if I stare at something long enough it hits me exactly what needs to happen to it. Without exception, every time I had a special piece of wood and I thought I knew what it needed to be, it just didn’t turn out. When it hits you, you know…and if you set it aside, but not out of sight, it will hit you and you will know. Sounds off the wall and maybe it is, but it works for me.
View LittleShaver's profile
LittleShaver
455 posts in 859 days
#2 posted 01-23-2018 01:34 PM
+1 on set it aside. I’ve had the same experience. Sometimes the wife will walk through the shop and spot something that needs to be something else. She is never wrong.
-- Sawdust Maker
View gargey's profile
gargey
1013 posts in 1015 days
#3 posted 01-23-2018 02:14 PM
Maybe you can sell it to a wacky kitschy bar or something. Very “out there” look.
