A Major Dilema
Forum topic by Jesse Schutt posted 03-29-2011 02:18 AM 1337 views 0 times favorited 8 replies Add to Favorites Watch
View Jesse Schutt's profile
Jesse Schutt
13 posts in 2716 days
03-29-2011 02:18 AM
I have a major dilema. I was given the opportunity to go into a Rockler store and pick anything that I wanted, up to $75, as a gift from a friend. Sorry guys, I have to admit… I choked! With so many options, I ended up just getting a gift card.
So now I need you to suggest what I should do with with a $75 Rockler gift card… and unless you can give me a REALLY good reason, I’m not sending it to you ;-)
8 replies so far
View DylanC's profile
DylanC
204 posts in 2703 days
#1 posted 03-29-2011 03:51 AM
If it were me, it’d be clamps, a vice or an aluminum router table plate….most likely the clamps.
-- Dylan C ...Seems like all ever I make is sawdust...
View Grandpa's profile
Grandpa
3259 posts in 2704 days
#2 posted 03-29-2011 04:05 AM
Tough decision. You would have to know what this person owns and the sizes. can’t get router bits unless you know the shank size and if he has them etc. Gift card is the way to go.
117128 posts in 3606 days
#3 posted 03-29-2011 04:12 AM
I guess it depends on what you have know.
View Rob200's profile
Rob200
313 posts in 3198 days
#4 posted 03-29-2011 04:14 AM
clamps is one thing you can have too many of
-- Robert Laddusaw and no I am not smarter then a fifth grader ( and no I canot spell so if it is a problem don't read it ))
View RGtools's profile
RGtools
3372 posts in 2683 days
#5 posted 03-29-2011 04:17 AM
I would build a custom “bench accessory pack”, 2 hold downs, one set of their plastic bench dogs, 2 metal dogs, 8 of the bench cookies with the risers, Then I would probably have enough for a microplane with interchangable blades and a small budget for jig hardware.
But that’s just me.
-- Make furniture that lasts as long as the tree - Ryan
TopamaxSurvivor
18293 posts in 3705 days
#6 posted 03-29-2011 04:28 AM
If you can not figure out what you need, then you’d best send it to me so I can fill out my Magswitch Starter Kit!
View Dan Lyke's profile
Dan Lyke
1520 posts in 4154 days
#7 posted 03-29-2011 06:13 PM
Do you have a good pull saw or three? I have one of the two-sided ones, which I’ve used for a number of small precise cuts, but I recently was exposed to the Bakuma 300 and now I don’t even think push saws are a good idea even for cutting 4×8 sheets of plywood the long way. So, my suggestion: two good pull-saws, one fairly aggressive, one gentler.
View knotscott's profile
knotscott
8057 posts in 3404 days
#8 posted 03-29-2011 06:51 PM
$75 would go a long ways toward a good saw blade if you don’t have one, or router bits, or a block plane, or a Grr-Ripper, or a …..it really depends on what you have and don’t have now.
