Non-carbide saw blades
Forum topic by MrRon posted 01-22-2018 06:32 PM 480 views 2 times favorited 12 replies Add to Favorites Watch
View MrRon's profile
MrRon
4991 posts in 3363 days
01-22-2018 06:32 PM
Topic tags/keywords: question
I have a few 10” saw blades, non-carbide that I will never use. What can I do with them? I was thinking of making scraper blades from them, but don’t know if the steel used is good enough for that. Does anyone know what type/grade of steel is used for saw blades?
12 replies so far
View LesB's profile
LesB
1801 posts in 3563 days
#1 posted 01-22-2018 06:50 PM
I too have a collection of blades. I keep telling myself I will save them to use if I have to cut some “dirty” wood. But, I never do. Maybe there is a metallurgist out there who knows the make up of the steel.
First of all I think even the thinest would be to thick to use as cabinet scrapers but it could work as a stiff paint scraper type.
I’m curious as to how you intend to cut them; especially without over heating them in the process and removing the temper.
-- Les B, Oregon
MrRon
#2 posted 01-22-2018 07:04 PM
I m curious as to how you intend to cut them; especially without over heating them in the process and removing the temper.
- LesB
My son who shares my shop, has a plasma cutter. If I knew the material, I would be able to heat treat if necessary. Maybe a cabinet scraper is not such a good idea. Any ideas what I could make from them?
View John Smith's profile
John Smith
1312 posts in 282 days
#3 posted 01-22-2018 07:05 PM
you can cut saw blades with a angle grinder with a “stainless” grade metal cut-off blade.
carving tools are the #2 choice with skinning/gutting sportsmen’s knives being #1.
lots of videos on the ole YouTube about repurposing circular saw blades .
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View Dutchy's profile
Dutchy
3066 posts in 2288 days
#4 posted 01-22-2018 07:09 PM
Normally these blades are made from CV steel, Chrome Vanadium steel
-- https://dutchypatterns.com/
View Woodknack's profile
Woodknack
12338 posts in 2500 days
#5 posted 01-22-2018 07:10 PM
Should be high carbon steel if they are any quality, a spark test will verify.
View Carloz's profile
Carloz
1147 posts in 711 days
#6 posted 01-22-2018 08:19 PM
What is “scraper blades” ?
Cabinet scrapers are much thinner so you could bend them a bit.
But there is a lot more you can do from non-carbide ( <—- this is important) saw blades. Carbide tipped blades probably use much softer steel for the body and are not suitable for anything.
1. Ninja Throwing Stars
2. Dowel cutting plate.
3. Pry bar/Paint scrapers.
4. Resharpen.
5. Wall watch face.
6. Riving knives.
7. Corrugated metal cutters.
8. Disk sander.
9. Frisbee that keeps players much more focused than a regular plastic frisbee disk.
Woodknack
#7 posted 01-22-2018 08:30 PM
. Carbide tipped blades probably use much softer steel…
- Carloz
Some do, some don’t, you have to test each one.
John Smith
#8 posted 01-22-2018 09:30 PM
Rick – that is a nice little test sheet to keep in the shop…....
I’ve never seen it before. thanks for sharing !!
View Ripper70's profile
Ripper70
1113 posts in 1028 days
#9 posted 01-22-2018 09:45 PM
Not sure if any of your blades would be suitable for these suggestions but it’s worth checking out.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
MrRon
#10 posted 01-23-2018 01:21 AM
Thanks all for the suggestions. I tend to procrastinate on implementing projects due to the multiple projects going on at any one time. Right now, that would be low on my priority list. When I’m doing a project, something always comes up to side track what I’m working on at the moment. The dangers of retirement. I need more time. Actually the saw blade thing came up as I was doing a project which was cleaning and organizing my shop. The saw blades which lay dormant for I don’t know how many years appeared while in the organizing process. I am presently going through withdrawal as I try to decide what to keep and what to send to the dump. For every 2 things I want to get rid of, one manages to survive to live another day. I am the ultimate hoarder. Anyone who saves scraps of wood knows what I mean. It has to be a disease. I realize it is not rational, but with guidance from my “organized” son, I will try to straighten myself out.
View Lazyman's profile
Lazyman
2393 posts in 1507 days
#11 posted 01-23-2018 03:25 AM
Walter Sorrells has a good spark testing video showing what the sparks actually look like here. Once you see this, the diagram Rick shared makes a lot more sense. After seeing this I went around testing every type of steel laying around in my shop, including a few of my cheaper tools.
If you are interested in knife making, there are tons of youtube videos where people use old saw blades for knives.
Woodknack
#12 posted 01-23-2018 03:49 AM
Good video Nathan.
Another tip, try annealing and re-hardening the steel from the sawblade because sometimes they use alloy steels that are very difficult to anneal or harden without a kiln.
