Doweling question
« back to Joinery forum
Forum topic by Andrew714 posted 01-22-2018 05:58 PM 322 views 0 times favorited 8 replies Add to Favorites Watch
View Andrew714's profile
Andrew714
20 posts in 1183 days
01-22-2018 05:58 PM
Topic tags/keywords: dowels glue-up
I have used dowels for a few projects, and I’m curious to hear how other people approach gluing them.
Method 1- Squeeze a little glue into each dowel hole, and let the glue squeeze into the dowel flutes
Method 2- Rub a little glue around the dowel before inserting it
Method 3- Use pre-glued dowels (coated with dry, water activated glue)
I have done methods 1 & 2, but I think they both have their drawbacks. With method 1, it’s hard to know how much glue is enough. I even had glue squeezing out of the end grain once, when the dowel was close to the end of the board. With method 2, your fingers always end up covered in glue, and it’s hard to avoid getting it all over the place. I also just found out that pre-glued dowels exist, so that seems like it would be a good solution too.
Thanks in advance for your thoughts and opinions on this.
Andrew
8 replies so far
9968 posts in 3555 days
#1 posted 01-22-2018 06:05 PM
I spread glue around the sides of the holes
using a little stick. I don’t usually coat the
dowel. I get little squeeze out when the
dowel is put in the first part. That’s ideal
imo. I wipe it off and then proceed to assemble
the parts together.
View Carloz's profile
Carloz
1147 posts in 499 days
#2 posted 01-22-2018 08:25 PM
Method-4. Do not use glue at all. Use wedges to expand the dowel.
View kdr152004's profile
kdr152004
19 posts in 690 days
#3 posted 01-22-2018 08:48 PM
I do method 1 and 2 combined.
Spread a thin layer around the dowel with a latex-gloved hand, then add a drop to each hole with a condiment-style bottle. I size my holes ~1/32’’ too deep to allow for the glue’s volume.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15133 posts in 2526 days
#4 posted 01-22-2018 08:55 PM
Cheap flux brush to spread glue in hole and onto dowel = no missed spots and less excess glue.
Wedged dowels = hard core. Very nice.
View theoldfart's profile
theoldfart
9419 posts in 2358 days
#5 posted 01-22-2018 10:01 PM
A little hint on the flux brush, trim about 1/3 to 1/2 the length off the bristles. Makes it less messy!
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Smitty_Cabinetshop
#6 posted 01-22-2018 10:04 PM
^ True Dat!
View Desert_Woodworker's profile
Desert_Woodworker
1308 posts in 1122 days
#7 posted 01-23-2018 01:39 AM
If you are able, find a source for “glue capsules”.
http://www.usifaz.com/adhesives1.html
-- Desert_Woodworker
Desert_Woodworker
#8 posted 01-23-2018 01:42 AM
