Repairing a crack
Forum topic by wseand posted 787 days ago 693 views 0 times favorited 21 replies Add to Favorites Watch
View wseand's profile
wseand
1549 posts in 1212 days
787 days ago
Topic tags/keywords: question refurbishing
I am repairing an old chair and when I was putting the back on, it cracked. Any ideas on repairing this. I really can’t take it back out again because it will probably just crack further and it is already glued in place.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
21 replies so far
View Bertha's profile
Bertha
13111 posts in 863 days
#1 posted 787 days ago
Are you planning on refinishing the chair?
wseand
#2 posted 787 days ago
Yes, probably a dark walnut. Looks really isn’t a factor. It is in bad shape and only used for toddlers. The lady just wants to keep it in the family. It is about 40 years old.
wseand
#3 posted 787 days ago
This is a picture of the chair, it is toddler size.
View David Kirtley's profile
David Kirtley
1250 posts in 1168 days
#4 posted 787 days ago
Without taking it all apart, I would see about some epoxy. Keep working it in until it wont take any more. Then wait and work it in some more. It should be fine and if not, you would have had to resort to scarfing in another piece anyway so you really don’t have anything to lose.
wseand
#5 posted 787 days ago
I will try that David. Thanks for the idea. I was thinking about some sort of spline but I thought it would just weaken the wood having to cut into it.
View 8iowa's profile
8iowa
1442 posts in 1931 days
#6 posted 786 days ago
I’ve had good luck thinning Titebond II slightly with water and letting it flow into cracks with a little help from a squeegie, and then clamping as best as I can. I recently fixed the crack in the forearm of an O/U shotgun this way.
87253 posts in 1747 days
#7 posted 786 days ago
Epoxy or layers of CA glue .
View GaryL's profile
GaryL
988 posts in 1001 days
#8 posted 786 days ago
I’ll put the third vote in for epoxy.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
wseand
#9 posted 786 days ago
Thanks gents I put some Epoxy in there and will see how it works. I am hoping not to have to do any surgery on it, I have already put butterflies and dowels in three places.
View tenontim's profile
tenontim
2129 posts in 1915 days
#10 posted 786 days ago
I vote for epoxy also. You might try putting the resin and hardener bottles in some very warm water for about 10 minutes,before you mix them, to thin it out. Then inject it into the crack with a syringe and needle. The warm mix will flow better but will cut down the cure time, so if you using the quick set epoxy, don’t waste any time getting it in there.
-- Tim-- http://www.tmuli.com
wseand
#11 posted 786 days ago
Thanks Tim, I opened it up as much as possible and got as much as possible in there, if it doesn’t work well I will end up scarfing some pieces on and making it look as good as I can.. Had to look up Scarfing, thanks for the lesson David.
View Tony_S's profile
Tony_S
252 posts in 1253 days
#12 posted 786 days ago
Wish I’d seen this a bit sooner. Typically, when I have to fix (or stabilize) a crack, a check or anything similar to the issues you have here, I do use epoxy (West Systems) But I thin it with Xylene first. You can thin the epoxy to such a degree(almost like water) that when you apply it to the crack with a syringe, the epoxy is drawn in very deep.
The epoxy takes longer to set up when it’s mixed with Xylene (depends how much you thin it), but other than that, it works very well.
-- Come to the dark side....we have cookies...
wseand
#13 posted 786 days ago
No worries Tony, I think I got in there pretty good.
#14 posted 786 days ago
http://www.amazon.com/M5-Thin-Viscosity-CA-Glue/dp/B000XIIZAQ this product is thin already. Turners use it all the time to file cracks .
wseand
#15 posted 786 days ago
Thanks Jim, I will have to get some and try it out.
