Favorite lamp hardware?
Forum topic by Jonathan posted 03-28-2011 07:29 PM 898 views 0 times favorited 0 replies Add to Favorites Watch
View Jonathan's profile
2608 posts in 2979 days
03-28-2011 07:29 PM
Where do you get your lamp hardware, such as sockets, switches, etc. from? I am especially interested in pull-chain style sockets, as well as the ones that have a little tab that you push in to the side of the lamp to turn it on or off.
I don’t really care for the ones that you have to twist/wind to turn the lamp on or off. That might seem like the way to go for the FLW lamps above, but I bet a pull chain would also work well for that design.
I would also consider using the ones that the switch is on the cord, enclosed in a little plastic case that has a wheel that you turn to make the lamp go on or off, or even a toggle type switch in a little plastic box on the cord.
I don’t mind spending a few extra dollars for something that looks nicer and functions better than the big box store stuff.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
0 replies so far
