Rikon 10-325 band saw
« back to CNC Woodworking forum
Forum topic by Calviregal9 posted 01-22-2018 03:32 PM 651 views 0 times favorited 10 replies Add to Favorites Watch
View Calviregal9's profile
Calviregal9
5 posts in 360 days
01-22-2018 03:32 PM
Bought new blade but guide dont work now it goes into wheel cant bring up to max height anly about 4 inches. Any suggestions..
10 replies so far
View DIYaholic's profile
DIYaholic
19738 posts in 2910 days
#1 posted 01-22-2018 04:24 PM
Pictures would help….
View HorizontalMike's profile
HorizontalMike
7770 posts in 3149 days
#2 posted 01-22-2018 04:35 PM
Max cutting height is advertised as 4-5/8in. and it is possible that it might be slightly less than that on individual saws. I get just slightly over that on mine.
Blade length should be 70-1/2in. Sounds like you bought a longer blade?
View ShaneA's profile
ShaneA
7063 posts in 2833 days
#3 posted 01-22-2018 04:59 PM
I was thinking cutting height on that saw was 13” Did you get the right length blade?
DIYaholic
#4 posted 01-22-2018 06:33 PM
- ShaneA
Yes, that saw has a 13” resaw height & uses a 111” blade.
View WhyMe's profile
WhyMe
1080 posts in 1796 days
#5 posted 01-22-2018 07:57 PM
Are you sure the saw is the 10-325 and not the 10-305 10”? The 305 has a 4-5/8” resaw height.
HorizontalMike
#6 posted 01-23-2018 11:42 AM
- WhyMe
DITTO!
I posted above before the OP changed the 10-305 10in to the 10-325 14in. Pretty sure the OP means the 10-305 10in BS.
Calviregal9
5 posts in 360 days
#7 posted 01-23-2018 09:07 PM
Owners manual. 14 Deluxe woodworking bandsaw model #10-325. Should of taken pics only 2 screws hold guide on . Worked before I changed blade now cranks into wheel , guess have to go to rikon dealer maybe figure out But thanksfor your time . Maybe another idea..
Calviregal9
5 posts in 360 days
#8 posted 01-23-2018 09:26 PM
- ShaneA
Calviregal9
5 posts in 360 days
#9 posted 01-23-2018 09:31 PM
- ShaneA
Ibought 111 blade manual calls for
Calviregal9
5 posts in 360 days
#10 posted 01-26-2018 01:40 AM
Got it working now goes up to maxium height… Had to make some adjustments this blade is a little wider than one that come with it but got it now….
