Update on Handy Drawer Clamp...Rust Question
Forum topic by BryanFaz posted 01-22-2018 04:26 AM 2180 views 0 times favorited 11 replies Add to Favorites Watch
View BryanFaz's profile
BryanFaz
51 posts in 409 days
01-22-2018 04:26 AM
Topic tags/keywords: handy manufacturing hand clamp wood id equipment restoration clamp
Quick update (pics) on the Handy Drawer Clamp restoration project. Here is the final product:
And our question. For a solid week we sanded, wire brushed, and angle grinded (word?) the steel pipes this top glides on. We used muriatic acid to clean the worst sections. We have sprayed every type of lubricant we can think of to stop or slow the rust. My associate, and proprietor, also primed then spray painted a woodburning stove at the same time (with an oil-based enamel, by Rust-Oleum!!) and a small amount of rust is appearing.
Any thoughts on how to slow the rust? The bare steel pipes that the clamp runs on in particular. Although frankly it doesn’t affect the clamp at all.
Oh…one other question. The wood that the top is made of is quite a story. The gentleman that owns the clamp, and designed the project, used wood that was the cross bars for the electric poles that were taken down and left on his property. They’ve been laying on the ground for a couple of years, and were in service for at least 15. I would describe it as medium hardness, medium weight, and it splinters easily. Here are some pictures:
And the end grain:
Look forward to reading your thoughts on these. Many thanks, as always!!
11 replies so far
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#1 posted 01-22-2018 05:08 AM
I would try wiping down the bare metal with a dilute phosphoric acid solution. Will convert any surface rust to a hard black coating (ferric phosphate) and help prevent future rust.
View Walker's profile
Walker
93 posts in 381 days
#2 posted 01-22-2018 05:17 AM
I have no idea what that thing is, but I know I want one.
is that like a giant pipe clamp of sorts? If so how does it work, and why are there drawers? Another night I have to explain to my wife why I was up until 2am googling tools I can’t afford…
-- ~Walker
BryanFaz
#3 posted 01-22-2018 05:40 AM
Not sure where to look for phosphoric acid solution (ha). Or how to work with it…carefully I’m sure. I wonder if the ferric phosphate coated would make the collar or housing that the clamping/moving end sits on tighter?. I’m sure its the wrong term, but the end opposite of the wheel moves…and 50-100 years ago this rascal was used as a furniture clamp. It has crushing strength. Anyway, the one end rides on these iron collars. Here is a picture of two of them, upside down. Someone can come up with the correct term:
I’m wondering if the coating would negatively impact how easy it glides? Might be worth a modest reduction if it reduced the rust.
Yes Walker…it basically is a large pipe clamp. It was sitting outside in my buddies farm…he acquired it roughly 10-15 years ago. He decided to restore it a few weeks ago and here it is. We added the drawers for functionality and looks.
BryanFaz
#4 posted 01-22-2018 05:44 AM
Here’s a picture i found online of one…without the top, of course. The top of my friends clamp is removable when he needs to use the clamp…otherwise, it’s one heckuva shop table.
BryanFaz
#5 posted 01-22-2018 05:48 AM
Brad, can you buy that phosphoric acid at a hardware store?
MrUnix
#6 posted 01-22-2018 05:53 AM
You can get it almost anywhere… hardware stores, tractor supply, any of the BORG’s… It’s about $15 for a gallon. Here is some Kleen-Strip stuff that you can get at home depot. I typically use that and dilute it 50/50 with distilled water. It’s not that harmful… same stuff in Coca-cola that you drink :)
BryanFaz
#7 posted 01-22-2018 05:56 AM
Well there ya go. Wonderful!! Sounds much worse. HA.
I will definitely give that a shot. Thanks a bunch!!!!!
View Woodknack's profile
Woodknack
11145 posts in 2289 days
#8 posted 01-22-2018 07:40 AM
Why is it rusting so aggressively despite being oiled? Is your shop really wet? Running a propane or natural gas heater? Condensation from being warm during the day and cold at night? Fresh concrete?
-- http://thewoodknack.blogspot.com/
View jerryminer's profile
jerryminer
890 posts in 1350 days
#9 posted 01-22-2018 11:00 AM
The wood looks like Douglas Fir—which is prone to splintering.
BryanFaz
#10 posted 01-22-2018 03:19 PM
Good question Rick_M. The shop is partially heated by a central air unit (heat pump) and it has an electric heater in the back room. the shop is roughly 15 years old. It has been quite cold…and we live in Western Kentucky, in the Ohio Valley. Pretty humid normally.
Douglas Fir? We thought it might be fir…but that was a guess. We certainly didn’t know what type of fir. Thanks jerryminer.
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#11 posted 01-22-2018 03:25 PM
I’m guessing the wood is western red cedar, it is commonly used for cross ties on electric poles.
-- Bondo Gaposis
