vacuum adapter for band saw
Forum topic by Karda posted 01-22-2018 01:48 AM 297 views 0 times favorited 2 replies Add to Favorites Watch
View Karda's profile
Karda
1382 posts in 789 days
01-22-2018 01:48 AM
Hi, I have a wen 10 inch band saw its has vacuum ports, naturally my craftsman shop vac won’t just plug in. what I have works but is a pain to work with. Does any body know how the after market accessories are measured. The closest I can find is 2.5 tp 1.25. ut nobody explains the measurements, are the out side or inside. I know what I ned but not how to explain it thanks
2 replies so far
View Gilley23's profile
Gilley23
489 posts in 617 days
#1 posted 01-22-2018 03:24 AM
I use this Ridgid hose kit: https://goo.gl/YgjK2a
It’s great quality and the adapters are not hard plastic so they fit the standard vac sizes as well as the close millimeter sizes.
Karda
#2 posted 01-22-2018 03:30 AM
I have a rubber reducer to 1.25 and clamped in a PVC coupling and sanded until the male end on my hose fit, problem is there is noway to tightend the hose clap on the BS nipple so it pulls out when I want to use the vacuum else where might just glue it in. I don’t want to buy a new hose
