Cleaning interior Table Saw Worm Gear
Forum topic by Silvio posted 01-21-2018 09:47 PM 759 views 0 times favorited 14 replies Add to Favorites Watch
View Silvio's profile
Silvio
40 posts in 641 days
01-21-2018 09:47 PM
Well it was time to clean my Powermatic 64A table saw interior and grease the worm gears. Time consuming but necessary to say the least. I started to notice my turn crank began getting hard to turn when approaching 35° thru 45°. I took a small brass brush and cleaned all the worm gear teeth. The teeth were caked with saw dust…I suspect this was the culprit for the hard turning. After a good brushing a shop vac cleaning and a good greasing with Rig Grease I decided to use my new digital angle gauge to reset both stops. I was able to set the 45° exactly were it needed to be at 90° to my fence. Couple small adjustments. Once putting everthing back together I cut a test piece at 45°…put it to a square
-- May The Attitude of Your Faith Always Enrich The lives of Others
14 replies so far
View Alex Lane's profile
Alex Lane
542 posts in 4131 days
#1 posted 01-21-2018 10:05 PM
I wonder if graphite dry lube would work in place of grease without catching sawdust.
-- Lane Custom Guitars and Basses
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#2 posted 01-21-2018 10:13 PM
I use paraffin wax dissolved in solvent (the options are abundant) to lube everything under the hood on my Unisaw and don’t have any issues attracting dust. A blow gun while the DC is running cleans everything quite well and reapplication takes no time at all only a few times per year.
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#3 posted 01-21-2018 11:00 PM
If you used grease… be prepared to do the whole procedure over again pretty soon. Wax or a dry lube is what you want as it won’t attract sawdust or accumulate gunk.
Silvio
#4 posted 01-21-2018 11:02 PM
Thanks for the info Brad
View Knockonit's profile
Knockonit
505 posts in 443 days
#5 posted 01-21-2018 11:37 PM
I use paraffin wax dissolved in solvent (the options are abundant) to lube everything under the hood on my Unisaw and don t have any issues attracting dust. A blow gun while the DC is running cleans everything quite well and reapplication takes no time at all only a few times per year.
- bigblockyeti
pretty much how i clean my uni saw, long tube air blower gets into all the spots, sure wished it had better dust pick up, lol, have taped and sealed every orafice in the dang thing, did help, but still a gaggle of it on top.
i used graphite a few times, but last time did the parafin wax the ole gal uses in her canning, hehe, if only she knew
sure is a pleasure to turn when lubed correctly
Rj inaz
Silvio
#6 posted 01-21-2018 11:46 PM
Oh…my wife says she has some…do you have to heat it up?
MrUnix
#7 posted 01-21-2018 11:54 PM
No heat needed. You can rub it on straight from the block, or you can shave off flakes and dissolve in mineral spirits. For those who don’t have it, you can pick up a pound of it at the local super market, walmart, hardware store, Amazon, etc… for about $2:
I use it both ways. For the dissolved stuff, a mason jar works great, and a small wire basket makes it easy to dunk small parts like nuts and bolts. Gets wax where you otherwise can’t normally get it. Pop it in the refrigerator for a bit and it will turn into a paste.
Silvio
#8 posted 01-22-2018 12:52 AM
Thank you my friend
View pontic's profile
pontic
664 posts in 849 days
#9 posted 01-22-2018 11:47 PM
Went to drylube works better.
-- Illigitimii non carburundum sum
Silvio
#10 posted 01-23-2018 12:30 AM
Ok..ill give it a try
View ohtimberwolf's profile
ohtimberwolf
882 posts in 2593 days
#11 posted 01-23-2018 12:32 AM
Sure would like to know how much paraffin to what amount of mineral spirits to make the mixture if someone doesn’t mind telling. Do you brush it, drip it or spray it on?
-- Just a barn cat, now gone to cat heaven.
MrUnix
#12 posted 01-23-2018 12:50 AM
See here: http://www.owwm.org/viewtopic.php?t=103911&p=712354#p712354
- ohtimberwolf
Yes :)
Brush, wipe, drip, dunk, spray, whatever it takes.
- pontic
I’ve got a couple cans of dry lube and have tried it quite a bit on various machine parts. To me, it just doesn’t seem to be as good a lube as more traditional stuff, you need to use quite a bit more than what I expected, and doesn’t seem to last very long. YMMV.
View OSU55's profile
OSU55
2033 posts in 2230 days
#13 posted 01-23-2018 01:01 AM
I use furniture paste wax instead of parrafin – harder than parrafin once dry. I find it lasts longer.
ohtimberwolf
#14 posted 01-23-2018 01:02 AM
Thanks Brad, I too have had bad luck with dry lube and it is not cheap. larry
