live center
« back to Woodturning forum
Forum topic by rusty2010 posted 01-21-2018 04:52 PM 470 views 0 times favorited 9 replies Add to Favorites Watch
View rusty2010's profile
rusty2010
151 posts in 2799 days
01-21-2018 04:52 PM
I have a 12” craftsman lathe. I would like to replace the dead center with a live center. Any help is
much appreciated.
-- check, recheck then check again
9 replies so far
View WhyMe's profile
WhyMe
1080 posts in 1802 days
#1 posted 01-21-2018 04:58 PM
What’s the MT#? I buy mine from here…. https://www.pennstateind.com/store/live-tailstock-centers.html
rusty2010
#2 posted 01-21-2018 05:31 PM
I don’t know , where would I find the mt#. Does the small spur remove and a live center go in that small space?
View Aj2's profile
Aj2
1953 posts in 2039 days
#3 posted 01-21-2018 05:38 PM
Rusty is there a hole on the other side? I taking about the complete opposite end this would be to drive out the dead center. It should be a taper lock fit. At least that how my craftsman lathe works. If you need a pic I can take one this after noon.
-- Aj
rusty2010
#4 posted 01-21-2018 06:24 PM
the spur is on the motor side ..and the tail stock center has a spur and threaded bar to tighten,, Does
the spur come out and a new live center replace it?
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#5 posted 01-21-2018 07:04 PM
I don t know , where would I find the mt#. Does the small spur remove and a live center go in that small space?
- rusty2010
Most likely a MT1 taper, but if you post your model number, that can be verified. And yes, the dead center should be removable (circled below):
You can probably figure out what taper you have (if you have one) by measuring. Here are the standard taper sizes: Dimensions of Standard Tapers
Easy to measure if you have a decent set of drill bits.
View Bill White's profile
Bill White
5149 posts in 4201 days
#6 posted 01-21-2018 07:10 PM
The live center does not install into the headstock. Goes in the tailstock.
Bill
-- bill@magraphics.us
WhyMe
#7 posted 01-21-2018 07:41 PM
Is this the style of lathe? http://www.vintagemachinery.org/pubs/222/2875.pdf
If so then the piece circled by MrUnix should also come out. Use the through hole to twist out the center.
View Aj2's profile
Aj2
#8 posted 01-21-2018 07:43 PM
Your lathe might be a but older then mine. Is this what your thinking.
-- Aj
rusty2010
#9 posted 01-21-2018 08:25 PM
Whyme, the piece that mrUnix circled does come out . The model# is 113 23800
