Can anyone give me a good place to buy a 220v extension cord?
Forum topic by RockyTopScott posted 03-28-2011 02:48 AM 6528 views 0 times favorited 8 replies Add to Favorites Watch
View RockyTopScott's profile
RockyTopScott
1186 posts in 3443 days
03-28-2011 02:48 AM
Topic tags/keywords: electrical
Need at least a 10’ cord
Thanks on advance
RTS
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
8 replies so far
View Loren's profile
10260 posts in 3613 days
#1 posted 03-28-2011 03:34 AM
I’ve made them in the past. Just get a 3 or 4 wire cable from
a hardware store (sold by the foot) and put a plug at each
end. Gauge is up to you, and I’m no expert, but 12ga 3 or
4 wire cable is probably adequate.
There are enough different configurations for 220 volt plugs
that extension cords already fitted with plugs don’t seem to
be an off-the-shelf thing.
View SWM's profile
SWM
94 posts in 3023 days
#2 posted 03-28-2011 03:46 AM
I echo Loren’s advice. Be sure to buy the service cord rated cable. It has a thick rubber casing to protect the conductor and can be easily adapted to any number of plugs. I just made one with the “twist-lock” plugs from HD. They’re fairly expensive, but really give a good seal (add a little sillicone) to keep dust out. Each plug will probably cost you about $20 each so you may have $50-$60 in the extension cord.
-- Working on a retirement hobby, only 30 more years to practice!
View Joe's profile
Joe
18 posts in 2656 days
#3 posted 03-28-2011 03:48 AM
I’ve made my own as well. As Loren states, you’ll have to pick the plugs to match your application. Voltage is the equivalent of pressure in a plumbing system so make sure you get wire rated for 220 volt or higher to insure it has the proper insulation around the wire to keep that voltage from coming through the insulation and shorting on something – like you.
-- Joe
View crank49's profile
crank49
4030 posts in 2936 days
#4 posted 03-28-2011 03:51 AM
You didn’t say what you would use it for. If it is for a stationary tool just do what Loren said, but if it is for a portable tool, like a floor sander or buffer, you need to use twist lock type plugs. In either case, be sure the plugs and cord you use are rated for 220 volt service, or higher; most are, but it never hurts to read the labels.
RockyTopScott
#5 posted 03-28-2011 03:58 AM
Hey Crank
I would like to roll my planer outside when it gets warmer.
crank49
#6 posted 03-28-2011 04:26 PM
RockyTop
Around here we never know when it will stay warm. 80 degrees a few days ago and frost on my windshield yesterday ;^(
View Briguy's profile
Briguy
21 posts in 2860 days
#7 posted 03-28-2011 04:58 PM
Any heavy equipment rental stores will have them, i.e. Battlefield Equipment Rentals.
View Albert's profile
Albert
508 posts in 3554 days
#8 posted 03-28-2011 05:21 PM
http://electrical.about.com/od/wiringcircuitry/a/electwiresizes.htm
This website will give you approximation on wire size needed, the longer the cord the more you will have to beef it up to compensate for resistance in the wire, depends on what size motor you will be running and the length of the cord.
