Is this Live Edge floating top table too narrow?
Forum topic by ThatDaveGuy posted 03-28-2011 01:42 AM 2718 views 1 time favorited 6 replies Add to Favorites Watch
View ThatDaveGuy's profile
ThatDaveGuy
4 posts in 2936 days
03-28-2011 01:42 AM
Hello everyone,
I am working on a live edge floating top cherry hall table.
Size,
Height – 30-3/8”
Table top width – 8-3/8” to 10-1/8”
Distance between front and back apron – 4-7/8”
Distance front to back, leg to leg – 7”
Distance between legs – 3-3/4”
I can still make it 1-2” wider, but I am not sure.
Thank you for looking,
David.
117091 posts in 3574 days
#1 posted 03-28-2011 01:48 AM
I guess only you can answer if it’s to narrow or not.
View drewnahant's profile
drewnahant
222 posts in 3086 days
#2 posted 03-28-2011 01:54 AM
really a subjective choice, I would be more concerned with stability than appearance, consider anchoring it to the wall. If it is for yourself, such that it is convenient, put it in place for a week before finishing. then you will know whether you like it, and whether you want to take up more of the hall by making it wider, or if you have any space issues.
View HawkDriver's profile
HawkDriver
447 posts in 2630 days
#3 posted 03-28-2011 03:12 AM
David,
I am curently working on a “console table” for the wife. It is similar in size to yours. The place it is going requires it to be narow also. It measures in at 11.75” deep. I believe the base different than yours(I did an inverted T design), but satbility seems to not be an issue. It will be sitting on tile, so i installed adjustable feet to make sure it would be completely stable in use. Hope that helps.
Pat
-- Patrick, Helicopters don't fly. They beat the air into submission.
View WibblyPig's profile
WibblyPig
172 posts in 3272 days
#4 posted 03-28-2011 03:33 AM
Dave,
Answered on your FB picture – oops, thought that was the osage orange plank.
-- Steve, Webster Groves, MO "A society grows great when old men plant trees whose shade they know they shall never sit in."
View Damian Penney's profile
Damian Penney
1141 posts in 3989 days
#5 posted 03-28-2011 08:54 PM
I think it’s too narrow for the base you have – if this is to be place against a wall perhaps use the front legs and attach the back of it directly to the wall – or have a single leg almost as wide as the board on each end.
View wseand's profile
wseand
2796 posts in 3039 days
#6 posted 03-29-2011 05:36 AM
I would go wider and think about only using three legs.
