Fixing a bad glue joint - saggy case
« back to Joinery forum
Forum topic by GabeATX posted 01-20-2018 05:40 PM 1554 views 0 times favorited 11 replies Add to Favorites Watch
View GabeATX's profile
GabeATX
11 posts in 916 days
01-20-2018 05:40 PM
Topic tags/keywords: question mistake
Hey folks, looking for some ideas on how to fix a mistake. I am making a credenza (walnut plywood and faceframe) with a 75” top and some vertical supports for drawers. Not sure how I did this, but I cut the supports too short and glued them up without realizing the error. —the top is now sagging, being pulled down by the vertical supports. Titebond III and it’s been sitting for a week, so no easy ctrl-Z.
The attached image kind of shows it, the corner joints are all good, but the vertical pieces are too short and the top is pulled into a sag. We’re talking 3/16” of sag.
I’m thinking of using circular saw to just cut the vertical pieces in half horizontally, then inserting a shim between the halves. Then use cauls/clamps to glue it up straight.
This inside area of the case will be hidden from view, so my main concern is whether it will be hard to end up with two perfectly parallel pieces on which to mount my drawer slides.
Here’s a drawing, the whole deal is a trapezoid but the top should be flat.
11 replies so far
View TheFridge's profile
TheFridge
10818 posts in 1728 days
#1 posted 01-20-2018 05:53 PM
Use a flush cut saw along the top?
View Woodknack's profile
Woodknack
12469 posts in 2622 days
#2 posted 01-20-2018 06:14 PM
- TheFridge
+1 then shim
GabeATX
#3 posted 01-20-2018 06:42 PM
OK, tried this and looks like it will work well. Certainly less destructive than the circular saw option. Thank you!
View shipwright's profile
shipwright
8189 posts in 3040 days
#4 posted 01-20-2018 06:49 PM
Consider switching to hide glue, hot or liquid. It can be reversed with the combined application of heat and moisture.
Many high end custom furniture makers use nothing else.
View Andre's profile
Andre
2375 posts in 2048 days
#5 posted 01-20-2018 06:53 PM
- shipwright
My only problem is for large projects not enough work time? And my Glue pot is to small! Maybe I am too slow?
shipwright
#6 posted 01-20-2018 11:02 PM
- Andre
That’s where you use liquid. Old Brown Glue is probably the best. Lots of open time for larger projects.
View Rich's profile
Rich
4013 posts in 831 days
#7 posted 01-21-2018 04:51 AM
- shipwright
Or make your own a lot cheaper. Since you already have the glue granules, all you need is urea and water. Recipes and directions are available online. Also, you can simply add urea to your hot glue pot. It won’t be liquid glue that you can store in a bottle, but it’ll extend the open time. Experiment with what works best for you.
View 000's profile
000
2859 posts in 1141 days
#8 posted 01-21-2018 05:13 AM
- shipwright
Or make your own a lot cheaper. Since you already have the glue granules, all you need is urea and water. Recipes and directions are available online. Also, you can simply add urea to your hot glue pot. It won t be liquid glue that you can store in a bottle, but it ll extend the open time. Experiment with what works best for you.
- Rich
I’m trying to make some right now.
The only hides I have are squirrel and rabbit.
I boiled them in water and am clamping them with my veneer press, but so far I’m not getting any glue.
TheFridge
#9 posted 01-21-2018 05:26 AM
This guy ^ :)
Was gonna make the same recommendation for HHG but deleted it. It really is great stuff.
View Rich's profile
Rich
#10 posted 01-21-2018 05:32 AM
I think shipwright keeps 50 or 60 lbs on hand, maybe he’ll share. Paul, I bought the 6 lb jar from Patrick. I’m more than half way through it. Where do you get yours? I thought those 6 lbs would last me a few years, but now that I’m a hide glue junky, it’s going fast.
shipwright
#11 posted 01-21-2018 02:33 PM
I have a lot of it at home for my students but not so much here. I have a friend in Tucson who bought a bag from Milligan and Higgins and I get mine here from him.
I’ll PM you.
