Rigid Oscillating belt and Spindle Sander
Forum topic by Kinbaum posted 03-28-2011 12:14 AM 1109 views 0 times favorited 1 reply Add to Favorites Watch
View Kinbaum's profile
Kinbaum
14 posts in 3164 days
03-28-2011 12:14 AM
I just purchased this sander from HD. My question is…..does the belt attachment tend to make far more noise than the spindle attachment. This is the case for my sander. I just want to be sure that this is normal. Also does anyone have issues with mild vibration of the sander? It also appears that the plastic enclosure makes noise….
Thanks
1 reply so far
View Sawkerf's profile
Sawkerf
1730 posts in 3216 days
#1 posted 03-28-2011 12:45 AM
If you’re hearing a “raspy” sound the comes and goes as the belt moves up and down, you probably need to adjust the belt tracking. That’s the knob on the right side of the belt attachment. I try to keep my belt as close to the top of the rollers as possible – and still staying below the table during the full oscillation.
If the noise is constant, make sure that you’re aligning the belt attachment correctly when you install it. I’ve sanded a bit of my table because of incorrect installation.
If that’s all ok, you’re probably fine. The belt sander is a little noisier – it has more moving parts.
