Which brand is the best for irons to a lathe ?
Forum topic by Napoleon posted 03-27-2011 10:52 PM 1292 views 0 times favorited 7 replies Add to Favorites Watch
View Napoleon's profile
Napoleon
788 posts in 2926 days
03-27-2011 10:52 PM
Topic tags/keywords: lathe
Hey everyone
As some of you know i just bought a lathe. I am wondering what brand in lathe-iron is the best ?
Its new for me so i would like to hear what all you people out there think ?
-- Boatbuilder&blacksmith
7 replies so far
View cut3times's profile
cut3times
116 posts in 3123 days
#1 posted 03-27-2011 11:01 PM
Thompson, but you will need to turn or buy your handles..
Thompson
-- And Still Too Short - "Life is what happens to you while you're busy making other plans." John Lennon
View Dan Katz's profile
Dan Katz
51 posts in 2756 days
#2 posted 03-27-2011 11:18 PM
Hi Nap,
I asume you are talking about lathe tools.
The best iron or steel that I have used is the cryo-tools by Richard Raffan
available at Woodturners Supply-Provo,Utah. They hold an edge a very long time.
If you need a set of decent inexpensive tools you can get a good set at Habour Freight.
But don’t by the cheap Windsor ones. Get the ones with the dark red handles.
-- VillageCarver,Chattanooga
Napoleon
#3 posted 03-28-2011 01:21 PM
Cut3times but then i need irons to turn the handels :D
Dan il take a look at them and also Thomson. Thanks both of you for taking time to write here.
Best regards
View richgreer's profile
richgreer
4541 posts in 3191 days
#4 posted 03-28-2011 03:54 PM
I’m not recommending a brand as much as I’m recommending a concept. I’m a big fan of the Easy Rougher and the other Easy Tools and the Eliminator tools
These tools all feature a carbide cutter that you do not need to sharpen. After 20 – 40 hours of use, you can rotate the cutter to work on different edges and eventually you have to replace the cutter.
This is a different way of turning. Check out the video.
Perhaps the only disadvantage for a new turner is that you may never master the “art” of using a gouge or skew properly.
http://www.woodturnerscatalog.com/store/Turning_Tools___Special_Purpose_Tools___Easy_Rougher___easy_rougher_ci1?Args=
http://www.woodturnerscatalog.com/cgi-bin/woodturners/dyna/dynadf2MGu?page_number=1
I do 99% of my turning with 2 carbide tipped tools, 3 different shaped scrapers, and 2 different sized parting tools.
View Bill White's profile
Bill White
5048 posts in 4077 days
#5 posted 03-28-2011 04:05 PM
Listen to richgreer.
Bill
-- bill@magraphics.us
View Bertha's profile
Bertha
13550 posts in 2810 days
#6 posted 03-28-2011 04:34 PM
I’ve been happy with my Sorby branded tools but I’m not a big lathe guy. I particularly like the “Skewchigouge” which is easier to handle than that pesky skew. If I had it to do over again, I’d go to the carbide tipped tools like the EZrougher above.
Napoleon
#7 posted 03-28-2011 11:16 PM
Richgreer i just looked at your link and see your point :)
