Need to locate wood vaneers
Forum topic by Jack Lewis posted 01-19-2018 04:49 PM 365 views 0 times favorited 6 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
267 posts in 1073 days
01-19-2018 04:49 PM
Some suggestions for GOOD source? Needed for contrast layers in Segmented wood turning.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View jmartel's profile
jmartel
7882 posts in 2145 days
#1 posted 01-19-2018 04:52 PM
Certainlywood.com has always been good to me. But it’s full length/width veneers typically, so might be larger than you are looking for.
View Loren's profile
10377 posts in 3643 days
#2 posted 01-19-2018 05:13 PM
There are a lot of retail sources. I haven’t
bought a lot of veneer but I’ve never had
a problem with it not being “good” stuff.
The thing that might concern you is thickness
as most veneer is cut to like 1/40th inch.
Finding thicker or thinner in the colors you
want may be a little challenging.
View AZWoody's profile
AZWoody
1330 posts in 1219 days
#3 posted 01-19-2018 06:04 PM
Ebay has a lot of sellers but like Loren said, a lot of veneer material is pretty thin.
I have ordered from there before and was able to find all kinds of species.
View shipwright's profile
shipwright
7980 posts in 2793 days
#4 posted 01-20-2018 01:44 AM
There are still a few sources of veneer thicker than the modern standard 1/42” but they are few and far between and don’t generally have a wide range of species. ... and very few exotics.
Certainly Wood (mentioned above) has a page called “special thickness veneers” that is worth checking out.
Constantine’s has some but again a small selection of domestics.
B&B Rare Woods has some 1/32” – 1/28” dyed veneer.
High quality (sawn) exotics in 1/32” – 1/16” and thicker are still available from a few custom cutters in Europe and that is a real option for high value pieces.
Of course if 1/42” is OK with you, there are as stated above lots of sources.
View Woodmaster1's profile
Woodmaster1
956 posts in 2582 days
#5 posted 01-20-2018 06:05 AM
You can resaw any type of wood a make your own. That is what a friend of mine does to get the contrast for segmented turning. Cut it, plain it and sand it. You will get great results and it will not cost a lot of money.
View splintergroup's profile
splintergroup
2007 posts in 1217 days
#6 posted 01-20-2018 03:42 PM
I got one of the marquetry “kits” from veneer supplies when he had a sale on them (they run out of stock fast on these so you’ll probably have to wait).
They are scraps of 1/40” veneers, but cost only pennies per square foot. I agree that Certainly Wood is a great source for thicker stock, but the species are more limited.
