Sizing picture frames
Forum topic by deadherring posted 01-19-2018 02:19 AM 721 views 3 times favorited 6 replies Add to Favorites Watch
View deadherring's profile
deadherring
81 posts in 1884 days
01-19-2018 02:19 AM
Hi,
I am making 3 picture frames out of walnut with maple inlay. Two will be the same size and one is a different size.
I’ve got the inlay done and the rabbets cut and am ready to cut the frame down to size.
Whats the best way to cut the frame to the right size? I cut everything too long on purpose , how do I make sure I cut everything to the right size and that the picture fits? (preferably without complicated math). I was thinking maybe I could cut each part close to what I need then keep checking and nibbling down until it fits perfectly, but I am using a miter sled and am afraid it increases the likelihood of two of the same sides being off by a little. Last time i made a frame i think I tried to get the cut close and then trimmed the picture by a little to make sure it fit, which seems backwards.
A second question is if anyone knows of good plans/a build video for a miter sled that incorporates one long side with a built in stop so I can use the stop to get exact matches. I built a miter sled, but the two sides are short and the best way I can figure is to stack two of the same sides one on top of the other, try to make sure the ends are aligned and hope for the best.
Thanks in advance.
Nathan
View msinc's profile
msinc
569 posts in 744 days
#1 posted 01-19-2018 02:56 AM
I posted the same question {about the best way to cut the miters} about a week ago…might want to do a search. There was some very good advice and information that got posted in response. I do several picture frames a month it seems like. There are many ways to do it but will say these two things…first, it is very important that the wood you are using for the molding is perfectly straight, dead on size and square. If it is not then you will have gaps at the miters. Second, make sure you take into account sizes to allow for various matting you may have around the pictures.
Do that search and you will find it, very good thread to read thru for anyone interested in picture frames. Best of luck!!!
View John Smith's profile
John Smith
1554 posts in 403 days
#2 posted 01-19-2018 04:07 AM
practice with cheap (true and square) 1×2 lumber before using the expensive stuff.
practice – practice – practice and practice some more.
-- I started out with nothing in life ~ and still have most of it left.
View lew's profile
lew
12512 posts in 3996 days
#3 posted 01-19-2018 04:35 AM
I found this on Saw Mill Creek. I did not write it.
https://www.dropbox.com/s/czq1ovjvelh6kkc/FrameCalculator.xls?dl=0
View 000's profile
000
2859 posts in 1140 days
#4 posted 01-19-2018 04:42 AM
Hi,
I ve got the inlay done and the rabbets cut and am ready to cut the frame down to size.
Thanks in advance.
Nathan
- deadherring
It’s really easy, no complicated math….just easy math.
Measure from the outside of the frame to the rabbet. (In my picture it’s 2”)
Measure your picture. ( my picture is 22 1/2”)
Decide how much play you want to give the picture, I’m going to make it 1/8” bigger than the picture.
So all you have to do is double the measurement from the outside of the frame to the rabbet,
that measurement is 2” so double it…4”
Now add 4” plus the amount you want to make it bigger by…1/8” = 4 1/8”
So the picture is 22 1/2…Plus the 4 1/8” = 26 5/8” This is the outside measurement for the frame.
(do the same thing for the opposite side)
View theart's profile
theart
68 posts in 795 days
#5 posted 01-19-2018 07:09 PM
Here’s my approach. No math or measuring required:
- Cut the rabbet.
- Cut a 45 on one end.
- Set the glass into the rabbet, with one side right up to the miter, and make a mark on the inside corner of the rabbet about 1/16” past the other side of the glass. Maybe a little farther, the glass doesn’t need to fit tightly.
- Use combo square to layout a 45 at the mark.
- Cut just past the line.
- Clamp a second board to the first, face to face. If using a sled, masking tape might be less cumbersome.
- Miter second board while clamped to the first.
Since the two boards were cut flush together on both ends while clamped, they are exactly the same length.
- Repeat with the other pair of sides.
View JBrow's profile
JBrow
1366 posts in 1161 days
#6 posted 01-19-2018 09:58 PM
deadherring,
“Woodsmith Shop” aired a program about picture frames which included a segment for building a table saw miter sled. Their sled seems to meet your requirements. The full episode and plans for the mitre sled come at a small price if the free preview is of interest.
Preview…
http://www.woodsmithshop.com/episodes/season5/511/
Mitre sled plans…
https://www.woodsmithplans.com/plan/table-saw-miter-sled/
