Pipe Clamp lengths
Forum topic by Justin posted 03-27-2011 03:39 AM 1918 views 0 times favorited 12 replies Add to Favorites Watch
View Justin's profile
Justin
119 posts in 2878 days
03-27-2011 03:39 AM
Topic tags/keywords: question clamp resource
I’ve ordered some pipe clamps from lee-valley because of the free shipping they have available until 28th. So ill need to pick up some pipes soon. I would like to be able to glue up table tops, cabinet doors, or cabinets when needed for a project, so i was wondering what length of clamps do you commonly use alot?
12 replies so far
View cabs4less's profile
cabs4less
235 posts in 2671 days
#1 posted 03-27-2011 03:41 AM
I never build doors over 2’ so i got a lot 3’ pipes and a couple 4’ and 5’ ones
-- As Best I Can
View lew's profile
lew
11946 posts in 3664 days
#2 posted 03-27-2011 03:46 AM
3ft to 4 ft are easy to handle but sometimes you’ll need longer ones. When you get the pipes, have them threaded on both ends. Then, get some 3/4” pipe couplers (nipples). That way you can connect your lengths of pipes together to make longer clamps.
View auggy53's profile
auggy53
159 posts in 2588 days
#3 posted 03-27-2011 03:47 AM
most of mine are 30’’ just because i buy 5 foot pipe and cut it off
-- rick
116912 posts in 3486 days
#4 posted 03-27-2011 03:48 AM
I always make my pipes at least 7” longer than standard measurements I have clamps from 16”- 104” .
View canadianchips's profile
canadianchips
2600 posts in 2906 days
#5 posted 03-27-2011 04:03 AM
3ft, 4ft and 6ft. I have threads on all the 3 ft to extend them if I need to.
View GMman's profile
GMman
3902 posts in 3606 days
#6 posted 03-27-2011 04:09 AM
If you thread your pipes a both ends you can make them in any length you need with couplings.
View brianinpa's profile
brianinpa
1812 posts in 3632 days
#7 posted 03-27-2011 04:18 AM
3’ is the longest I use, but that can be extended using GMman’s idea. Another nice thing is that pipe is cheap.
Justin
#8 posted 03-27-2011 04:20 AM
that’s a good idea, i never even though about buying couplers and having both ends threaded. ill have to remember that when I go to buy the pipes. It would come in handy if i every need to glue up something wide.
it seems like 3’ and 4’ is used a lot and if i get both ends threaded i could easily make 6’-8’ or longer if needed.
View Brian024's profile
Brian024
358 posts in 3309 days
#9 posted 03-27-2011 04:51 AM
Be careful if you go to Home Depot and plan on getting black pipe, some of the stores won’t cut or thread black pipe since it is used for gas line.
View Viking's profile
Viking
880 posts in 3104 days
#10 posted 03-27-2011 05:17 AM
My 3/4” pipe sections are 3’ and 5’ and have a bunch of couplers to make longer ones. I buy galvanized pre-threaded pipe then, before using, I chase the threads with a die and wire brush them which make installation of the clamps and unions very easy.
Also have an odd assortment of 1/2” pipe clamps (these were my first clamps from Sears about 35 years ago) and pipe sections from 2’ to 5’ for smaller projects.
I also keep a bunch of the thread protectors that come on the pipe and keep the unused threads protected and clean.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View childress's profile
childress
841 posts in 3450 days
#11 posted 03-27-2011 07:59 AM
I think I bought 10’ pieces which were threaded on both ends then cut it at 3’ and had a 7’ pieces left over. I use those for bigger butcher blocks and so forth…. I believe that was the cheapest way to go and you get 4 clamp sizes out of two pipes.
-- Childress Woodworks
View bubinga's profile
bubinga
861 posts in 2576 days
#12 posted 03-27-2011 08:21 AM
Hardware stores sell all differant lengths already threaded on both ends,pick your length and go
I use 4 ft the most ,other typs of clamps for smaller stuff
-- E J ------- Always Keep a Firm Grip on Your Tool
