Whiteside Router Bit Help
Forum topic by Chris_T posted 03-27-2011 02:47 AM 1040 views 0 times favorited 7 replies Add to Favorites Watch
View Chris_T's profile
Chris_T
94 posts in 2759 days
03-27-2011 02:47 AM
A while ago I bought a Whiteside 1 1/4” bowl and tray bit to use with my router planer. I haven’t been able to use it because it is not long enough to make contact with the wood I’m trying to plane. Could I use it with a collet extension or is that a bad idea? Any help would be greatly appreciated
7 replies so far
View GaryK's profile
GaryK
10262 posts in 3954 days
#1 posted 03-27-2011 02:54 AM
You could use an extension but with that diameter of a bit you will probably get a lot of deflection giving you a rough surface.
I don’t think that I would recommend it. If you do decide to do it I would take very light passes.
Chris_T
#2 posted 03-27-2011 02:57 AM
Is there something else I could do that would work better?
View drewnahant's profile
drewnahant
222 posts in 3054 days
#3 posted 03-27-2011 03:03 AM
the key is to reduce the distance from the router motor to the wood, usually by making the board your router is mounted to thinner, which ends up meaning steel, aluminum, lexan, something stronger and stiffer than wood. maybe you could post some pictures of your router planer setup, so we could see about modifying that.
Chris_T
#4 posted 03-27-2011 03:12 AM
Ok, I will try to post pics tomorrow.
Chris_T
#5 posted 03-31-2011 01:17 AM
Sorry it took so long.
View mchuray's profile
mchuray
81 posts in 2963 days
#6 posted 03-31-2011 04:56 AM
Maybe I’m obtuse. Why can’t you raise the board to meet the router bit instead if trying to move the bit to meet the wood. By blocking up the wood you can get the bit closer then your setup will work just fine.
Mark
Chris_T
#7 posted 03-31-2011 05:19 AM
I have done that before but it still doesn’t really work. I will post a pic of the bit lowered as far as it will go. I think the only solution to the problem is to make the sled adjustable.
