Best "value" TS blase for making box joints
Forum topic by Dwain posted 01-17-2018 07:37 PM 327 views 0 times favorited 4 replies Add to Favorites Watch
View Dwain's profile
Dwain
584 posts in 4099 days
01-17-2018 07:37 PM
Topic tags/keywords: box joint jig table saw blade
I’d like to start making box joints. I am without a router table at this time so I have to use a table saw. I believe this will necessitate the purchase of a new blade that can create flat bottomed kerfs. I don’t want to spend a ton of money, so I’d like some suggestions as to a good “value” choice.
Thanks to all!
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View TheFridge's profile
TheFridge
10818 posts in 1726 days
#1 posted 01-17-2018 07:47 PM
Look up the William Ng box joint jig on YouTube. It works great.
View Gilley23's profile
Gilley23
489 posts in 622 days
#2 posted 01-17-2018 08:13 PM
As simple as it gets: https://youtu.be/AiPzFNsuN2k
View brtech's profile
brtech
1054 posts in 3162 days
#3 posted 01-17-2018 08:28 PM
View knotscott's profile
knotscott
8180 posts in 3615 days
#4 posted 01-17-2018 08:39 PM
There are several 24T rip blades that have a flat top grind (FTG) that will work. Best bang for the buck in a full kerf blade is likely the Delta 35-611
Otherwise, you may need to look into a box joint cutter set, or use an FTG chipper from a dado set.
