Live oak
Forum topic by darrenjttu posted 03-26-2011 02:36 AM 1995 views 0 times favorited 3 replies Add to Favorites Watch
View darrenjttu's profile
darrenjttu
83 posts in 2968 days
03-26-2011 02:36 AM
About to cut down a live oak tree. How is when milling. How is it when drying? What thickness should I cut it if I want 3/4 inch thick after drying?
3 replies so far
View superstretch's profile
superstretch
1531 posts in 2569 days
#1 posted 03-26-2011 04:43 AM
From what I know, oak is pretty hard and will dull tools pretty quickly. If you’re rough sawing it at a saw mill, that shouldn’t be too much of a problem. I’d say somewhere between 4/4 and 5/4 and drying for at least a year. I guess the rule of thumb is at least a year per 4/4. Personally, I like working with red oak. I don’t know how much it compares to other woods, but it does go out of true pretty regularly as it dries or after milling. (joint and plane it and see how much it warps by the next day)
-- Dan, Rochester, NY
View Scsmith42's profile
Scsmith42
125 posts in 2552 days
#2 posted 03-26-2011 05:30 AM
Darren, some species of LO can move quite a bit during drying. If your tree has grown fairly straight, you should be ok.
Re thickness to mill, typically FS boards are milled at 1-1/16”, QS and RS boards should be milled at 1-1/8” if you want them to clean up at 3/4.
Any defects in the board will usually cause movement and the board may not clean up at 3/4.
If you have plenty of wood and want to be conservative, mill it at 5/4.
-- Scott, North Carolina, www.quartersawnoak.com
View richgreer's profile
richgreer
4541 posts in 2950 days
#3 posted 03-26-2011 03:22 PM
The rule of thumb I’ve always heard is to dry 1 year plus 1 year for each inch of thickness. 1 inch – 2 years. 2 Inches – 3 years etc.
