Has Danish Oil Changed?
Forum topic by Steve posted 01-17-2018 05:07 PM 1198 views 1 time favorited 26 replies Add to Favorites Watch
View Steve's profile
Steve
76 posts in 1247 days
01-17-2018 05:07 PM
Topic tags/keywords: question
Danish oil is a favorite of mine and I’ve been using it for years. It’s simple to apply and the results are consistent, at least until recently. The last 2 or 3 cans I’ve purchased (over the last year or more) have been downright syrupy in their viscosity. If I let it dry on the surface for the recommended 15 minutes or so, the excess will have turned to a honey-like substance—thick enough to drag the lint and fibers from even “lint-free” rags.
I happened to pull an old can off the shelf last week, their ‘walnut’ color, which I bought at least 10 years ago and rarely use. When I applied that, it went on like water—just as it ought.
Has anyone else experienced this? It’s possible that they’ve changed their formula, I suppose. Also possible that I have cans formulated to conform to our air quality rules (though nothing on the can suggests this).
-- ~Steve
26 replies so far
View AESamuel's profile
AESamuel
88 posts in 1460 days
#1 posted 01-17-2018 07:21 PM
Just dilute it with some mineral spirits and that will get the viscosity you want!
View Steve Peterson's profile
Steve Peterson
395 posts in 3319 days
#2 posted 01-17-2018 07:56 PM
Out here in California, all of the finishes have new formulas. Even mineral spirits that AESamuel suggests as a thinner are different. And many of them only seem to be available in small containers.
I think it is an issue that is unique to California, but the manufacturers might simplify their inventory by using the CA formula for everyone.
-- Steve
View Gilley23's profile
Gilley23
489 posts in 619 days
#3 posted 01-17-2018 08:06 PM
Can’t you Commifornia guys just mail order what you want instead of buying the crap that they let you have?
View htl's profile
htl
4321 posts in 1396 days
#4 posted 01-17-2018 08:10 PM
Last I bought at Home Depot In Alabama was just fine a month ago.
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
Steve
#5 posted 01-17-2018 08:20 PM
Can t you Commifornia guys just mail order what you want instead of buying the crap that they let you have?
- Gilley23
My operation isn’t big enough to be inspected, so in theory, yes. But, a friend who does car interiors gets regular visits from the air quality management district. And the fines can be both large and hard to fight.
I stick with what I can find at the store.
-- ~Steve
Steve
#6 posted 01-17-2018 08:25 PM
- Steve Peterson
Apparently, the stuff in Alabama is still kosher, so odd that there’s no mention on the package. How do they keep their inventory straight?
I’ve kinda given up on the stuff they sell as mineral spirits—no punch at all. What’s marketed as paint thinner, though, seems to work ok as a substitute.
Glad to know I’m not going nuts.
-- ~Steve
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#7 posted 01-17-2018 08:48 PM
The “green” mineral spirits (aka: paint thinner) sucks. If you see on the label that you need to shake well before use, and that it’s non-flammable – run away from it fast. Not only is it really bad as a thinner, but it is a terrible cleaner as well. Here is the composition of the Crown “NXT” stuff – pay particular attention to the main ingredient :
They also have a low-VOC formula which doesn’t list water as the main ingredient, but shows it’s only 15-40% petroleum distillates and the rest ‘proprietary’ – but still says it’s non-flammable and to shake well before use. Still garbage.
Here in Florida, it’s difficult to find real mineral spirits at the big box stores, as they are all pushing the low VOC green crap. But it’s still available at paint stores, like Sherwin Williams. Just gotta check the label when you buy it, and look for:
View RobS888's profile
RobS888
2522 posts in 2082 days
#8 posted 01-17-2018 08:57 PM
I have noticed that on some Watco Natural Danish oil, but subsequent cans have been nice and thin. It felt like it was full of resin. I’m using some Cabot Marine varnish right now for a mail box and it was as thick as this stuff.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View Walker's profile
Walker
155 posts in 709 days
#9 posted 01-17-2018 10:13 PM
Danish Oil is kind of a generic term. There are lots of different products with varying ingredients that are labeled Danish Oil. “Tried and True” brand has less awful chemicals. As for the Watco, I haven’t noticed it being any thicker but I have noticed my home depot stopped carrying the larger cans.
If you’re having trouble with the wiping off, try just letting it dry then rubbing it down with #0000 gauge steel wool.
-- ~Walker
Steve
#10 posted 01-17-2018 10:53 PM
Danish Oil is kind of a generic term. There are lots of different products with varying ingredients that are labeled Danish Oil. “Tried and True” brand has less awful chemicals. As for the Watco, I haven t noticed it being any thicker but I have noticed my home depot stopped carrying the larger cans.
If you re having trouble with the wiping off, try just letting it dry then rubbing it down with #0000 gauge steel wool.
- Walker
Yep, been doing a lot of that. One of my projects uses embedded rate earth magnets as door closers. It was a bear to get to fine metal particles cleaned out, but the finish came out ultra-smooth.
-- ~Steve
RobS888
#11 posted 01-17-2018 11:03 PM
- Walker
I can decant Watco Danish oil into other containers and it lasts a long time, but the thick ones I had went bad pretty quickly. Like in a few days.
View htl's profile
htl
#12 posted 01-17-2018 11:59 PM
I need to restate what I said cause I was thinking the Minwax brand of Danish oil not Watco which I have never tried sorry.
Steve
#13 posted 01-18-2018 01:32 AM
I have noticed that on some Watco Natural Danish oil, but subsequent cans have been nice and thin. It felt like it was full of resin. I m using some Cabot Marine varnish right now for a mail box and it was as thick as this stuff.
- RobS888
I wish there was some way to tell before I buy. I’ve had 3 or 4 bad cans, all Watco, in a row. I wore it down only minutes after application, which helps. Sometimes, though, it feels oily to the touch for up to a week afterwards.
-- ~Steve
View Knockonit's profile
Knockonit
504 posts in 439 days
#14 posted 01-18-2018 02:25 AM
californication rules on magic elixirs is assinine, in any event, a lot of products for tile sealing, roof urethane, and regular caulking sealeants that are ok in other states are not in cali,
i was in the bay area working on the mil house, and looking for some stuff i use here in az, ole boy told me they hadn’t sold that stuff in cali in years, oh well, no wonder the paint falls off the joints over there so fast.
Gilley23
#15 posted 01-18-2018 03:16 AM
As beautiful as Commifornia is as a state, I’ll never live or visit there. They’ve f’d themselves out of commission, it’s only a matter of time. If at all possible just mail order what you need and get the products as they were intended.
