Jointer Extensions
Forum topic by WoodTwirp posted 01-17-2018 02:28 AM 537 views 0 times favorited 3 replies Add to Favorites Watch
View WoodTwirp's profile
WoodTwirp
12 posts in 386 days
01-17-2018 02:28 AM
Hi All – I am building a queen size bed frame and one of my challenges is jointing the side rails to get the flat and square. I have a 52” bed on my jointer and the side rails are 80” roughly. I have the Delta DJ15 and was wondering if anybody had any ideas for extensions be it steel or home made. I searched Youtube and only found one of which was flimsy at best. Any thoughts?
3 replies so far
View bilyo's profile
bilyo
474 posts in 1341 days
#1 posted 01-17-2018 03:17 AM
I just finished a similar project starting with rough 5/4 walnut. I also have a relatively short jointer, but I didn’t use it for the rails. I flattened one face of each rail using a sled for my planer. Then, of course, flattened the other face as usual. The edges were squared up using the table saw. Remember, the rails don’t need to be quite as square and straight as if you were going to edge glue them. In this case, if you are careful, they will be straight enough for the purpose. I don’t like that statement either, but it’s true.
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#2 posted 01-17-2018 04:13 AM
You can use a single roller stand for outfeed support as long as it’s set dead even with the outfeed bed.
Another thing that helped me is lubricating the jointer beds with Bostik Glide Cote or similar. Less feeding pressure is required, and seems to give better control at the jointer.
If that doesn’t work, do what I did and upgrade to a DJ-20. I think you could joint an eight footer on that beast.
View Kirk650's profile
Kirk650
585 posts in 987 days
#3 posted 01-17-2018 12:01 PM
What pintodeluxe said will work just fine. For the pencil post bed that I made, I used two of the Ridgid stands and it worked perfectly. You’ll need a long straight edge to set the stands to the exact height needed.
