SOSS Hinge Query
Forum topic by Richard Lee posted 01-17-2018 01:30 AM 365 views 0 times favorited 4 replies Add to Favorites Watch
View Richard Lee's profile
Richard Lee
183 posts in 944 days
01-17-2018 01:30 AM
For those who have used and installed these hinges.
They are set flush or slightly below ,is there supposed to be a gap when they are closed ?
Thanks
View Andre's profile
Andre
2115 posts in 1975 days
#1 posted 01-17-2018 01:40 AM
I set them almost flush when I used them. The chamfer will still be visible?
Richard Lee
#2 posted 01-17-2018 01:47 AM
What Chamfer ?
View jerryminer's profile
jerryminer
944 posts in 1611 days
#3 posted 01-17-2018 05:40 AM
There may be a small gap even when the hinges are set flush. Look at the hinge itself —out of the door. When the hinge faces are parallel, is there a gap? that gap will exist between the parts when the hinge is installed flush. To eliminate the gap, set the hinge deeper.
I find it is easier to cut the mortise a little “extra” deep, and shim with cereal-box cardboard if needed—- easier than re-routing the mortise.
The weight of the door can also be a factor—requiring the top hinge to be set deeper than the bottom hinge.
Soss hinges are fussy. I mostly use Tectus adjustable hinges now.
edit: another thing that may be a factor: if the screws are not driven straight, the screw heads may be binding on each other.
Andre
#4 posted 01-17-2018 07:02 AM
What Chamfer ?
- Richard Lee
The Chamfer on the door frame/edge.
