Seeking Bandsaw Blade Recommendations and Insight
Forum topic by BattleRidge posted 01-17-2018 12:10 AM 1096 views 0 times favorited 9 replies Add to Favorites Watch
View BattleRidge's profile
BattleRidge
86 posts in 457 days
01-17-2018 12:10 AM
I would appreciate any recommendations and insight in regard to bandsaw blades.
My shop presently consists of a 10” table saw, a 10” radial arm saw, scroll saw, router & table, as well as a selection of handheld power tools and other items. I am purchasing a bandsaw to increase my capabilities and am now down to finalizing my blade selection. After much research and consideration I have chosen the Laguna 18BX. (Sidenote: At some point in the future I may possibly purchase a 10” Rikon (or perhaps a used 14” saw) for smaller / detail work and to fill the gap between my scroll saw and the 18BX, but until then the 18BX will be my only bandsaw and I have other equipment needs before an additional bandsaw.)
Specifications:
18” bandsaw
Motor – 3hp, 230v
Blade length – 145”
Blade width – 1/8” to 1-1/4”
Resaw capacity – 16”
Throat – 18-7/32”
Guides – Laguna Ceramic
Weight – 410 lbs
My most frequent tasks will be:
General woodworking with a variety of wood ranging in thickness from 3/8” to 3/4”, as well as 2” thick stock. Projects will include a multitude of decorative and craft-type projects, furniture making (primitive & simple designs and not so much fine furniture), and similar projects.
Resaw work will include a multitude of full 2” thick boards ranging in width from 5-1/4” – 8”. I have a one-room schoolhouse (unfortunately beyond affordable restroation) that has an addition that was used for farm-type purposes, and I will be dismantling the building and repurposing the wood into useful products, requiring some of this wood will be resawn into thinner stock.
I may also do some limited tinkering around with a smaller log sections to create cookies or similar cuts, or to possibly create an occasional small project board. This will be conducted within the capabilities of the saw and my other equipment (chain saw, etc.) will be used where appropriate.
Also, my eventual plans are to obtain a portable sawmill to make use of the many hardwoods on my 103 acre tree farm. This wood will be cut to size, air or solar-kiln dried and used for a variety of projects, occasionally requiring further cutting and resawing on the bandsaw or other equipment.
Bandsaw blade collection I am considering:
Laguna Resaw King (carbide), 1”, 3-4 Variable TPI
Lenox Diemaster 2 (bi-metal), 1/2”, 4 TPI, Skip Tooth
Lenox Diemaster 2 (bi-metal), 3/8”, 10-14 Variable TPI
Lenox Diemaster 2 (bi-metal), 1/4”, 6 TPI, Skip Tooth
My intent is to be able to perform a multitude of functions with the saw, and additionally to learn of and refine my personal bandsaw abilities & needs. I have a preference toward quality and longevity, and thus my choice of brand-name carbide and bi-metal blades.
Any thoughts or opinions are welcome and it can be most helpful to hear of real world experience. I have done several hours of research but want to be sure I am on the right path before making a purchase.
Attached are pictures of the school and some of the type of products the saw will be used for. (Note: The school picture is mine, the other pictures were obtained elsewhere.)
Thank you in advance!
9 replies so far
View TungOil's profile
TungOil
1088 posts in 736 days
#1 posted 01-17-2018 12:25 AM
I have no experience with the Laguna resaw blade but I use the Lenox blades exclusively on my MM16 and they work very well. From your list I’d skip the 3/8” blade. The 1/4” and 1/2” are most useful in my mind. I also have a 3/4” that I have not had an opportunity to try yet and a 1” carbide resaw blade that works really well.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Aj2's profile
Aj2
1953 posts in 2039 days
#2 posted 01-17-2018 12:43 AM
I would skip the RK blade i see nothing in your work that justifies that blade. It’s a great blade for very precise joinery or Resawing veneer or bent lamination. Think along the line of very expensive woods like highly figured Koa or Mahogany. Every bit of the wood is precious and expensive.
-- Aj
View JBrow's profile
JBrow
1366 posts in 1161 days
#3 posted 01-17-2018 03:01 AM
BattleRidge,
I have been satisfied with the Lennox 1/2” Tri-Master carbide tipped bandsaw blade as a general purpose blade. It has done a good job of producing true resaw cuts and curves.
http://www.lenoxtools.com/pages/tri-master-carbide-band-saw-blades.aspx
Carbide tipped bandsaw blades are expensive and the possibility of the band breaking before the teeth are dull exists. Buying a carbide tipped bandsaw blade whose length is near the upper range that will fit the saw could save the price of a replacement for a broken blade. A broken blade may be repairable but doing so could shorten the blade. Buying a blade on the longer side could allow the broken and re-welded blade to still fit the saw.
View BandsawJeff's profile
BandsawJeff
52 posts in 442 days
#4 posted 01-17-2018 03:09 AM
I pretty much use a 3/8” 3tpi blade for everything. I go with any brand I can get my hands on…but my favorite has been the timber wolf.
Check this video out though. Goes through clearly all the different sizes and shapes of bandsaw blades and when to use them. It may help you decide!
https://m.youtube.com/watch?v=sZ-33ZN49os
BattleRidge
#5 posted 01-19-2018 01:57 AM
I am leaning toward the 1” Resaw King blade and with the amount of lumber I need to cut, as well as the lack of a jointer / planer, the RK may best suit my needs. I am also considering using a less-expensive blade to supplement the RK, particularly when working on questionable pieces of wood and would like to avoid contacting any steel. A metal detector is on my list but I still have more research to do in that area.
Given the combination of saw blade cost and shipping charges, I may focus on both the 1/2” and 1/4” blades and add any others later when (and if) needed. This will be my first bandsaw and as I become more familiar with it and as I begin to evaluate my needs and uses, I can then make any adjustments.
The 18BX is rated for 143-3/4” – 145-1/2” blades and I am planning on using the recommended 145” length. I hadn’t considered the changes a broken blade repair could create, but hopefully will have enough leeway should it ever be necessary. One of the reasons I am going with the 18” over the 14” saw is to hopefully limit some of the stress on the blade to prolong it’s life.
I checked out the video and it was helpful. I’ve been digging around online for everything I can find and had not yet seen that particular video.
Thank you for the insight and it has been quite helpful. I am still weighing the many options and hope to lock things in soon. I am purchasing the saw tomorrow and am looking forward to putting it to use.
View Mario's profile
Mario
182 posts in 3637 days
#6 posted 01-19-2018 02:09 AM
I currently have two 14in bandsaws in the shop, one with a 6in riser block and a Resaw King installed, the other with a 1/4 Wolverine blade. I use the Resaw King quite a lot for a variety of cuts, it cuts quite fast and smoothly, once you adjust it to your bandsaw it works like a charm, highly recommended.
BattleRidge
#7 posted 01-20-2018 08:11 PM
I made my final choice and placed the orders for new blades last night – the 1” Laguna Resaw King, & the bi-metal Lenox Diemaster 2 in both a 1/2” 4 tpi and 1/4” 6 tpi size.
Wood Werks in Columbus has 10% off machines this weekend and without the $75 shipping charge that other dealers require this made the saw the cheapest I have found it. My Chief Financial Officer (wifey) and I made the 80 mile trip to Columbus on Friday and purchased the saw (which is now sitting in the back of my pickup).
While in Columbus, we also went to ‘The Woodworking Shows’ which is at the state fairgrounds this weekend where (among other things) we had the opportunity to see Alex Snodgrass and his bandsaw clinic. While I have seen many of his videos online, it was a true pleasure to see him in person and to have the opportunity to speak with him after the clinic, and additionally to speak with his father and meet Alex’s wife. They are truly a class act with a wealth of helpful information and knowledge.
Thank you to all who responded and I very much appreciate the insight and the multitude of perspectives. In some ways it can be mind boggling, but it allowed me the opportunity to dig deeper into the individual aspects. I am looking forward to putting the saw to use and with my three-blade beginning, I should be able to get a good idea of what works best for my individual needs and for my various projects, where I can further adjust and refine in the future if needed.
View Jim Finn's profile
Jim Finn
2688 posts in 3163 days
#8 posted 01-20-2018 10:16 PM
Often overlooked are the Supercut blades. I use their “gold” resaw blades to resaw with. Best I have found and not expensive.
-- No PHD just a DD214 Website> craftingcouple.com
View NoSpace's profile
NoSpace
153 posts in 1482 days
#9 posted 01-21-2018 03:26 AM
Hah, I really liked the supercut gold blades, and they were may fav. until I got the lennox trimaster, and I haven’t had to buy a blade in two years now so almost can’t remember what’s it’s like to have to buy blade.
