1/4 gap between Mantel top and wall
Forum topic by trevorlamont posted 01-16-2018 11:02 PM 841 views 0 times favorited 23 replies Add to Favorites Watch
View trevorlamont's profile
trevorlamont
15 posts in 2204 days
01-16-2018 11:02 PM
Hey guys, I’m building a mantel and come to find out I didn’t frame the wall perfectly straight. I am painting the mantel but I need advice on how you guys would fill the gap. I’ve considered caulk but I’m worried it will look bad. I’ve read about how people will use spackle. I attached a picture. Thanks for the advice!!
https://s3.amazonaws.com/vs-lumberjocks.com/p2o7p1g.jpg
23 replies so far
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
#1 posted 01-16-2018 11:14 PM
I had the same issue with a mantel, and I scribed the mantel to the wall for a tight fit. Just run a carpenters pencil against the wall, and mark the line on your project. Then belt sand it to fit.
trevorlamont
#2 posted 01-16-2018 11:19 PM
Wow, that’s a great recommendation. I should have posted here first. So the problem I have is 1. I don’t have a belt sander. That is on my list of tools I need still for sure. 2. The bigger problem.. I already secured the mantel top.. slap my forhead
- pintodeluxe
View alittleoff's profile
alittleoff
541 posts in 1518 days
#3 posted 01-16-2018 11:35 PM
You might look at running a small piece of moulding across the back. I’d rather do that than caulk it.
Gerald
View Ripper70's profile
Ripper70
1196 posts in 1150 days
#4 posted 01-16-2018 11:43 PM
You might look at running a small piece of moulding across the back. I d rather do that than caulk it.
Gerald
- alittleoff
+1 Better to creatively hide the mistake rather than try to patch it with less than the desired results.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Luthierman's profile
Luthierman
222 posts in 1329 days
#5 posted 01-17-2018 01:03 AM
You can also remove the drywall from the footprint of the mantle as well and it will sink right back in the hole.
-- Jesse, West Lafayette, Indiana
View Clarkswoodworking's profile
Clarkswoodworking
288 posts in 375 days
#6 posted 01-17-2018 01:09 AM
As a journeyman drywall taper I would have to say mud it
I wish I was close I would come whip it out for you !
Ripper70
#7 posted 01-17-2018 03:43 AM
- Clarkswoodworking
Now, wait a minute…
View GR8HUNTER's profile
GR8HUNTER
5404 posts in 954 days
#8 posted 01-17-2018 03:44 AM
if your painting it BONDO :<))
View Rich's profile (online now)
Rich
4013 posts in 831 days
#9 posted 01-17-2018 03:56 AM
- Clarkswoodworking
Now, wait a minute…
- Ripper70
“Excuse me while I whip this out” — Blazing Saddles
View jerryminer's profile
jerryminer
944 posts in 1683 days
#10 posted 01-17-2018 05:27 AM
The right way to do this is to scribe it to the wall. (Too late to detach, scribe, and re-attach?). second best is to mud the wall and repaint (mask off the mantle first.). Third, Bondo.
View ScottM's profile
ScottM
702 posts in 2388 days
#11 posted 01-17-2018 01:53 PM
+1 for adding trim.
View tomsteve's profile
tomsteve
897 posts in 1461 days
#12 posted 01-17-2018 02:27 PM
id go trim or scribe it. bondo or mud i think wouldnt be wise as wood moves and the two of those would eventually crack.
but then again i have the same problem with my mantel. i dont notice it unless im cleaning the mantel.
View bbasiaga's profile
bbasiaga
1242 posts in 2237 days
#13 posted 01-17-2018 02:39 PM
Pretty sure some genius of days gone by invented quarter round trim for things just like this….:)
Smitty_Cabinetshop
15831 posts in 2860 days
#14 posted 01-17-2018 07:49 PM
Scribe, remove, fit it properly, reinstall. You know that’s what should be done.
View builtinbkyn's profile
builtinbkyn
2702 posts in 1182 days
#15 posted 01-17-2018 07:56 PM
Trim would spoil the look – especially if you’re going for a floating shelf look. It’s already been said and I second, scribing the wall or mudding the hollow. If you mud the hollow, add some plaster of Paris powder to the mix.
-- Bill, Yo!......in Brooklyn & Steel City :)
