Polyurethane/Oil Stain compatibility
Forum topic by dbw posted 01-16-2018 05:05 PM 687 views 0 times favorited 9 replies Add to Favorites Watch
View dbw's profile
dbw
229 posts in 1872 days
01-16-2018 05:05 PM
Topic tags/keywords: stain polyurethane diluting
I’m curious as to why Polyurethane is “lifting” some of the oil based stain. I stained a piece of cherry wood with GF warm cherry stain. I let it dry for 48 hours @ 75 degrees and 50ish humidity. I wiped on Minwax gloss poly with a cotton rag and some of the stain came off onto the rag. This process gave the stain a brownish tint. Am I doing something wrong or is this normal?
-- measure 3 times, cut once
9 replies so far
View TechTeacher04's profile
TechTeacher04
396 posts in 1766 days
#1 posted 01-16-2018 05:14 PM
I have had the same problem, I always views that as par for the course. Maybe I am wrong too. In my experience the only way to prevent it is to spray on the finish. I have had the same diluting of the stain in both brushing and wiping finish applications. The second coat goes on without additional problems.
You might also look here, same problem
http://www.sawmillcreek.org/showthread.php?138651-Brushing-on-poly-but-the-stain-comes-off-on-the-brush
View bilyo's profile
bilyo
468 posts in 1337 days
#2 posted 01-20-2018 11:08 PM
I’ve also had this happen. Usually, when it does, it is because I didn’t wipe the excess stain off thoroughly enough after letting it penetrate as directed. I have done this intentionally a few times in order to get the color as dark as I want it. Having done this I will then flow on or spray on a coat of shellac to stabilize the stain and then continue with the finish I want.
I assume the “brownish tint” is not something you wanted. I don’t think this is related. Most stains will look somewhat different after applying a coat of finish. It is best to test it first.
View Imakenicefirewood's profile
Imakenicefirewood
77 posts in 1591 days
#3 posted 01-21-2018 01:30 AM
A good way to help prevent this is to seal the piece after the stain is dry. An oil-based sanding sealer or a de-waxed shellac have worked well for me.
View NoSpace's profile
NoSpace
151 posts in 1475 days
#4 posted 01-21-2018 02:30 AM
right, on two things, I don’t use stains anymore but back when I did, really got to wipe off the excess and that stuff takes forever to dry. Then, as said, spray one coat of canned shellac from HD (making it easy) to seal, sand it and then poly is good.
View dbw's profile
dbw
#5 posted 01-21-2018 05:40 PM
Y’all were correct. I waited 15 minutes and then I wiped off the excess stain. No more transfer. I think 15 minutes was a bit too long because very little stain wiped off and the color is very deep.
View Lazyman's profile
Lazyman
2703 posts in 1622 days
#6 posted 01-21-2018 06:13 PM
Not sure about the GF oil based stains but you might want to try really buffing or burnishing the stain with a coarse shop rag before applying the topcoats. You want to buff vigorously enough that you get just a slight warming effect. This will help both remove any stain not bound to the wood and the warmth may help speed the drying/curing of the stain.
View dbw's profile
dbw
#7 posted 01-21-2018 07:13 PM
Will a micro fiber rag work as a burnishing rag? I received 25 of them for Xmas.
View Rick S...'s profile
Rick S...
10925 posts in 3268 days
#8 posted 01-22-2018 05:31 PM
NO, it’s not normal. The stain was not dry enough and the Poly lifted or mixed with it.
I usually give the stain 24 hours to dry, it’s been Brushed in well. if I sense it’s not completely dry I’ll Burnish it with a clean rag and allow a bit more drying time.
I use a water based Poly on top. No problems at all Unless it’s NOT dry. Then you have a problem!
-- Made In Ontario, CANADA
Lazyman
#9 posted 01-23-2018 01:15 AM
- dbw
Probably not the best choice because they are fairly smooth but any rag will work. I find that a coarser weave sort acts like a very fine sandpaper but without removing any wood so you don’t have to worry about sanding through the stain. I usually use shop towels I find in the Home Depot paint department.
