Sketchup - Copy/Paste?
Forum topic by Tedstor posted 03-25-2011 10:50 AM 4170 views 1 time favorited 5 replies Add to Favorites Watch
View Tedstor's profile
Tedstor
1643 posts in 2601 days
03-25-2011 10:50 AM
So I started using Sketchup a couple months ago. Very nice program. Easily worth twice what I paid for it :)
One feature I have not stumbled upon is a method for copy/pasting components.
Say you’re desiging a table with fancy legs. You spend 30 minutes adding all the painstaking details into the leg. Do you have to spend another 90 minutes drawing the other three, or is there a way to simply copy and paste the next three?
I’m sure the answer is probably obvious, but I haven’t found it yet.
Any takers?
Thanks,
Ted
5 replies so far
View Tinnocker's profile
Tinnocker
107 posts in 2969 days
#1 posted 03-25-2011 11:11 AM
Hi Tedstor,
To copy use the move command and press the control button one time, then click on the object and move it to it’s new location. You can then right click it and use the flip command to flip it along one of the axes to face it in the proper direction.
Hope that helps you,
Ted
-- Ted, Browns Mills, NJ http://www.twhgrafx.com/blog/ Darn! I cut it 3 times and it's still too short! I get ideas for things that I can make to make things easier for me to make!
View KylesWoodworking's profile
KylesWoodworking
281 posts in 2661 days
#2 posted 03-25-2011 01:21 PM
Yes, Ted is right, just use the move copy command. I found some great video tutorials here if you want to check them out.
-Kyle
-- http://www.kyleswoodworking.com http://www.facebook.com/kyleswoodworking
Tedstor
#3 posted 03-25-2011 02:57 PM
Thanks fellas.
View Hoakie's profile
Hoakie
306 posts in 4004 days
#4 posted 03-25-2011 03:32 PM
if they aren’t completely symmetrical, make sure you use the “Flip along” (right click on a selected component) then the appropriate axes so if you modify one, they all get modified but in the right direction. I found this very useful instead of trying to manually rotate.
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View lew's profile
lew
12019 posts in 3723 days
#5 posted 03-26-2011 04:55 PM
Here are some resources that may be helpful-
http://www.srww.com/google-sketchup.htm
http://sketchupforwoodworkers.com/
http://sketchupdate.blogspot.com/2009/03/woodworkers-3-sketchup.html
“The Missing Manual” series. The title is Google Sketchup. The ISBN number is 978-0-596-52146-2.
http://sites.google.com/site/lewiskauffman/shared-files- Betsy.PDF- Betsy.PDF
