Sharpening for Woodturners advice wanted
Forum topic by steve3604 posted 258 days ago 191 views 0 times favorited 12 replies Add to Favorites
View steve3604's profile
steve3604
11 posts in 268 days
258 days ago
Topic tags/keywords: lathe sharpening
I need to invest in some sharpening equipment for woodturning tools, besides the waterstones I currently have.
would like some opinions on the wolverine jig system, and others that are similar.
My needs will be mainly for gouges (including fingernail profile) skews etc.
thanks in advance
any opinions appreciated
steve in Ind
View lew's profile
lew
1689 posts in 283 days
258 days ago
I use the Tormek system with the gouge jig. It was expensive but now Jet has an almost exact system at a much lower price.
Lew
6517 posts in 379 days
258 days ago
Steve, I use a white stone on the grinder and have made several wooden jigs for the various chisels, saves a lot of expense at minimal cost. There is good information on the www if you look around.
View GaryK's profile
GaryK
8541 posts in 516 days
258 days ago
I use a Tormek like Lew.
View cajunpen's profile
cajunpen
5345 posts in 594 days
258 days ago
Steve, I’m with Grumpy. I have a white stone on my grinder and have made a few wooden jigs to hold the tools at the proper angle. Works great and is inexpensive to set up.
View relic's profile
relic
315 posts in 465 days
258 days ago
Steve I use the wolverine system, and am quite happy with it.
-- Andy Stark
View Alin Dobra's profile
Alin Dobra
316 posts in 416 days
258 days ago
Steve,
Most professional woodturners use a grinder. The Tormek might be a fantastic sharpening system in most situations but on most woodturning tools you need a burl to cut properly not a perfectly sharp edge. I know it sounds weird, but a perfectly sharp tool gets blunt within seconds on bowls. The only tool I would consider using a “fine sharpening” solution is on a skew for spindle work. The skew is useless for bowls, though. By the way, David Ellsworth, one of the most prolific woodturners, goes at length on his video on this topic and explains why you want a grinder.
The solution I use is the Wolverine jig on a 8” slow speed grinder (the grinder Woodcraft sells). Most pieces of advice you get from woodturners is to use an 8” not a 6” grinder (10” is better but expensive). Also, you should sharpen with a 100-120 grit stone. I have the Wolverine jig with the Irish/Ellsworth grind attachment and I could not be happier. It usually takes me 30 seconds to resharpen my gouge. If you want to make bowls, you have to resharpen you tool every 10 minutes, so the fastest the resharpening the better.
I also made wooden jigs but in the end I was frustrated. The Wolverine is much nicer, stable and easier to setup. It will set you back about 100$ but it is worth it.
I hope this helps,
Alin
-- -- Alin Dobra, Gainesville, Florida
View Stacey's profile
Stacey
19 posts in 284 days
257 days ago
Steve,
I’ll second Alin’s recommendation for a slow speed 8” grinder and the Wolverine Sharpening System. It really does make sharpening quick and efficient. I also have the Ellsworth side grind jig for bowl gouges and couldn’t be happier. I picked up Woodcraft’s 8” slow speed grinder which they put on sale periodically. I believe it comes with a 60 grit and a 120 grit wheel.
While I haven’t had any experience with other systems like the Tormek, it is my understanding that they are geared towards flat bevels like plane irons and bench chisels…Some of you other turners out there might could comment on the use of this system for the curved edges on gouges.
Best.
-- S. Box --- "But a Constitution of Government once changed from Freedom, can never be restored. Liberty, once lost, is lost forever." - John Adams
Alin Dobra
257 days ago
Stacey,
You can use the Tormek for any profile and they have an Ellsworth grind attachment. The only trouble is the fact that it is slow and it does not leave a significant burr to turn efficiently. A super sharp edge cannot take the punishment of turning large pieces.
Alin
View jeffthewoodwacker's profile
jeffthewoodwacker
202 posts in 332 days
257 days ago
I have a 10” slow grinder with a white wheel and use the wolverine jig for my turning gouges. Recently watched an expert on sharpening use the side of the wheel to sharpen his skew—did a great job and just had to touch it lightly to the side of the grinding wheel. For my plane irons I use water stones and a piece of flat steel. You can get a burr with the leather strop on a Tormek but it is time consuming. I would spend the extra money and get a 10” slow grinder and put white wheels on it. The wolverine jig is well worth the investment.
-- Genius is immediate, but talent takes time.
2057 posts in 550 days
257 days ago
I use a wolverne jig to get my initial shape to the sweet spot then I do all my touch ups with the lee Valley sander grinder.
I have better control it seems of how the edge is honed.
steve3604
257 days ago
thanks for all the great replies its most appreciated
steve in Ind
View jimp's profile
jimp
44 posts in 289 days
257 days ago
Alin & Stacey -
I’m new to woodturning and I just got the Wolverine Sharpening System. I’m using a 6” grinder instead of an 8” grinder, because I already had the 6” grinder. It seems to do a pretty good job sharpening my lathe tools. What type of benefits do you get when you use an 8” grinder over the 6” grinder? Thanks.
JIM
Bookmark And Share This Page
